are reissue model t's setup for el34's?
  • are reissue model t's setup for el34's?
    a buddy of mine has one of these and hasn't been able to find a schematic or an answer? so if you have a schematic or know where i could find one that would be great? if you have a reissue model t running on el34's and have any opinions that would be great also?
    thanks, rylan
    The model T's use 6L6x4. I would imagine the OT primary is too high to run el34's unless you use a lower secondary tap. However, i know nothing about a reissue or whether they are different. But the word reissue generally means a clone of the original so i doubt they'd be set up with EL34.
      yeah, i don't know anything about the amp other than it's loud and really just a fender. he was hoping it would just be a matter putting a jumper from pins 1 to pins 8 and swapping the screen resistors out for 1k's and a quick bias. i would just open it up and have a look but we don't live that close to each other.
