Does anyone have a source for GOOD P-90 bobbins? I got some of the allparts ones and they just SUCK. They're flimsey, bend and flare like crazy, and everyone needs to be de-burred. Worst bobbin i've ever seen
Good P-90 bobbins?
They work OK - but the glue joint I just dont trust. I wind P-90's with a fair bit of tension and the ends flare alot on me. Im very petrified about pinching the wire in the joints. I've put the tooling in storage for now and will try again at a later time.
Originally posted by David King View PostLocal, old school winder of pedal steel pickups, Dan Shields, had his son cnc his one-piece bobbins from delrin sheet stock. They worked out great except for the cost.
Greg
Well I made a delrin bobbin yesterday and it turned out quite well! I used a 1/4 slot blade to slot the inside of the bobbin. I was also able to bond two magnets to it with silicone cement as well which is nice. Without any wire on it it actually flared inwards a little bit from the stress release. I made it with a 1/4" tall coil height and a 0.09" top and bottom. Though I may try it with a 1/8 top and bottom so that I can just machine it direct from 1/2" delrin so I dont have to stress release it.
That is nice plastic. mills, drills, and taps like a dream.
Thanks to whoever suggested it
b.
