Sovtek mig 50 Transformerchange II
  • Sovtek mig 50 Transformerchange II
    Hello
    Still needing help determining whitch trafos I need for my Sovtek mig 50.
    Data
    Amp : Sovtek mig 50 head orange edition (not midget)
    tubes : 2x 6p3s (6l6) power
    : 2x 6n2p preamp
    : 1x 6n1p ph.Inv (i think)
    ot - 4,8 and 16 ohms - 50 watts
    pt - 230 volts primary. filaments 6,3 volts.
    pcb - printed 007
    I think i can determine the ot myself, as i've been told that any 50w marshall replacement ot will do. - (correct me if i'm wrong.)
    But the trouble is determining whitch pt I need as there are several outputs needed for connecting the components in the amp (pcb, rectifier etc.)
    Can anyone tell me what voltages I need on the secondary ?
    Various schematics from the web doesn't seem to comply to my amp, also the have not the voltages printed on.
    grateful from any help and/or comments
    Poffa
    The output tranny needs to have a plate to plate impedance for a pair of 6L6 tubes. You may end up with a output tranny for a Marshall with EL34's.
    "Tubes and More" sell a power tranny that would work. Look up a 290DX transformer. Of course you need to consider the physical size and mounting orientation. I'm assuming you have no low voltage devices like OpAmps or relays. I'm not familiar with this particular amp.
      Thanks I'll check it up
        Mercury magnetics sells a replacement in the Axiom line: Mercury Magnetics - misc. amp transformers
        it is very expensive though
          A few years ago, I bought replacements for a Mig100h from New Sensor for $25 each, power and opt. Maybe email them and see if they have any left.
          www.youtube.com/sicherheit
          www.myspace.com/microwaves
            Wow...thats a screamin' deal if they're good quality.
            Give unto me a bit of flooring under this fat floating sofa.......
              New Sensors prices have gone up quite a bit.
              Helping musicians optimize their sound.
                sovtek mig 50 transfo
                Hey poffa,
                I have the same amp: Sovtek Mig 50 orange edition.
                Have you found which output and power transfo could replace the old ones?
                Let me know if you have any news or any deals !!
                pyo
                  PCB layout
                  I want to build Sovtek Mig 50 amp from scratch, would it not be too difficult for someone to take a high-res picture of the printed circuit board solder and components sides?
                    All you need is the schematic to built the amp.
