info on extra tap (extra orange wire) from internal transformer in old SM57, SM58s
  • info on extra tap (extra orange wire) from internal transformer in old SM57, SM58s
    found a couple used SM58s REALLY cheap (about $3 ea.) but the catch was that they were in REALLY crappy condition (worn finish, dented grills, bits of rust). Anyway, was looking at them and noticed some things that seemed odd about them, namely a "DUAL IMPEDANCE 50 & 150 OHMS" marking around the band at the base of the grill plus what was apparently an extra orange wire coming from the internal transformer that did not appear to be connected to the XLR output at the bottom of the mic. So, after initially finding a sliver of info (a slight mention of "a secondary tap on the transformer that was eliminated about 15 or 20 years ago related to a 50 ohm output impedance condition that was no longer a factor") on the Shure site, I didn't turn up much. However, after more persistent digging, I finally turned up what looks to be the best and clearest info on this, so here it is for anyone that happens to wonder about this and look for information on this:
    from Tim Vear of Shure back in 1995:
    A Short History of the SM57
    The Shure Model SM57 is a unidirectional (cardioid) dynamic microphone.
    It employs the Unidyne III cartridge, originally used in the Model 545.
    The Unidyne III is the third generaton of the first Unidyne cartridge used
    in the Model 55 in 1939. The Unidyne II was used in the "small" Model 55S
    brought out in 1950. The 545 was introduced in 1959 and the SM57 followed
    in 1965. The Unidyne III was designed primarily by Shure engineer Ernie
    Seeler.
    The SM57 was offered as a high quality microphone for speech applications
    in broadcast, recording and sound reinforcement. Though the microphone
    achieved some acceptance in the broadcast field, its ultimate success was
    with live sound applications and recording. By about 1968, the SM57 had
    been "discovered" by the fledgling concert sound industry. To engineers
    at that time (and now as well) the microphone presented a very useable
    tool: wide frequency response with an intelligibility enhancing presence
    peak, a very uniform cardioid polar pattern to minimize feedback and other
    unwanted pickup, and an affordable price (the original retail price was
    about $85 with cable).
    Over the years the SM57 has established itself as the second-most popular
    microphone in the world (after the SM58). It is widely used in both live
    sound and recording applications, in particular for vocals, guitar
    amplifiers and snare drums. It is used in such a large variety of
    situations that it often tops engineers' lists of "the one microphone to
    be stranded with on a desert island."
    Concerning changes to the SM57 since its introduction: there has not been
    a major change to the basic microphone design. However, there have been
    numerous small changes and improvements in the intervening 30 years. Here
    are some of the more noticeable ones:
    1. Original separate male XLR end cap was integrated into one-piece
    handle casting (1960's).
    2. Original metal closing ring (houses cartridge body) changed to plastic
    (at least twice).
    3. Plastic closing ring changed back to (current) metal (at least twice,
    last time in the 1970's).
    4. Brown "gooey" transformer potting compound changed to RTV silicone
    (1970's).
    5. Metal side screen eliminated from grille assembly (1970's).
    6. Grille locking ring strengthened (1980's).
    7. 50 ohm tap (orange wire) eleminated from transformer (1980's).
    8. Black ground wire to cartridge replaced by ground tab on XLR connector
    (1990's).
    The essential cartridge parts (diaphragm, voice coil, magnet, pole piece,
    acoustic resistance network, shockmount) remain as originally designed.
    Output level has remained constant as has the polar pattern. The overall
    frequency response of today's units is still within a few dB of the
    original test curves.
    Shure's basic philosophy on the SM57 (and other classics) remains: "if it
    ain't broke, don't fix it!"
    Tim Vear
    Applications Group
    Shure Brothers Inc
    http://groups.google.com/group/rec.a...7c76ec5f45db0?
    On this page I found a schematic for a Shure SM56 with the orange tap !
    User Guides and Spec Sheets Discontinued Microphones
    http://www.shure.com/ProAudio/Downlo...c_mics_content
    'Aint hystry intressting.............
      cool thanks! Just looked inside one, and it seems to be the same color code (a blue to pin 2 and and red wire to 3, black wire to shield pin 1).
        here's a thread on another site showing a newer SM57 diassembled with the internal transformer removed from the housing. Looks like the color code hasn't changed (primary is yellow and green, secondary red and blue).
        http://homerecording.com/bbs/showthread.php?t=273513
          someone was nice enough to scan the old technical datasheet for the SM57, so (with their kind permission) here it is for anyone looking for it.
          (BTW, does anyone know what Shure means when they say the impedance is "38 ohms (70 ohms actual)", and "150 ohms (310 ohms actual)"?)
