Results 1 to 25 of 25
Thread: Mesa boogie 50/50
    New Member brewu22's Avatar
    Nov 2006
    3
    0
    Mesa boogie 50/50
    If I am asking a dumb question, sorry in advance. Why did Mesa build a amp with no bias adjustment? With no adjustment, what tubes can I replace the stock tubes with?
    NYC
    1,656
    Received: 7/0
    14
    The bias on a Mesa amp can be changed it just doesnt have an adjustable bias pot,but like many other amps you need to either change a resistor or replace it with a pot.Mesa's scheme is that if you use their tubes you dont need to rebias the tubes are pre tested,sorted and coded.If you contact them they will get you the tubes that will be safe in that amp.If you want to use other than Mesa or GT's you have to have the bias checked,just like many Marshall and Fender users do all the time.
    Jun 2006
    California, USA
    3,554
    Received: 130/0
    Given: 90/1
    16
    Decided to jump into this...
    Mesa Boogie has their own philosophy about bias adjustment or, more accurately, the lack thereof. You can read Randall Smith’s view at http://www.mesaboogie.com/US/Smith/biasadjust.html
    In the paper he says “The short answer is that during my 12 years of repairing Fenders, one of the most frequent problems I saw was bias controls that were either set wrong or that had wandered out of adjustment due to vibration.
    Interesting take. After my 41 years of experience repairing Fenders I say that the most frequent cause of incorrectly set bias is replacement of the tubes without a re-bias. Yes, you can now buy replacements that are graded the same as your old tubes so that you can replace them without re-biasing. This assumes that the supplier is still around and has not changed their grading methods. In the old days, tubes were not supplied with any grading numbers and matched sets were a special order. However, I think that there was much less variation in characteristics between individual tubes of the same type.
    Concerning the ” wandered out of adjustment due to vibration” statement. I have never seen any significant evidence of that. If an amp with a decent adjustment pot had been vibrated that severely I say it’s time for a look inside the chassis anyway.
    If we apply the above two statements to guitars we could make the case that the tuners should be removed to prevent mis-adjustment by the user and changes due to vibration.
    Another part of the white paper Mr. Smith says “It only takes a moment and a volt meter: The Fender diagram shows how: Adjust this trim pot for - 52 volts. That's it. Nothing more”. He is saying tongue in cheek that if you always set the bias voltage to the same value anyway then you don’t need an adjustable circuit. Just design the bias circuit so that it always produced the same voltage.
    To this I say HOGWASH. I have never seen a Fender schematic that said "Adjust this trim pot for - 52 volts." There is a reference to –52 volts but that’s just a nominal value. A starting point if you will. Those in the know have been setting the bias current by adjusting the bias voltage for decades. As it turns out, -52 volts worked pretty good for most tubes available in the ‘60s but it hardly ever is a good setting for today’s tubes. An adjustable bias lets you set up the amp correctly and since there is an acceptable range it allows you to customize the sound to your needs. Yes – you do need to know what you are doing.
    MB says that if you buy their tubes, you can just pop them in the amp and they will be biased correctly. Does this mean that they reject a high percentage of the tubes they buy because they fall outside their acceptable parameters? The article says they do but I doubt if the percentage is very high. In fact, when you actually get their tubes they come graded with colored dots. The instruction sheet with the tubes says to use all the same color dotted tubes in your amp or put one of each color on each push-pull side to maintain balance. In reality MB amps are biased so cold that you would be hard pressed to get into trouble by ending up with any power tube biased too hot. IMHO the MB sound does not come from the power amp section anyway so the biasing isn’t as critical to the overall sound as it is for a classic Fender or Marshall.
    As far as I’m concerned Mesa Boogie can design their amps any way they want. Some features of their products are very good and I like their customer service. However, it pisses me off when they bull shit me with the stuff discussed above. To me this really makes it hard to keep reading the article even though there is a fair amount of correct information.
    I think I’ll stop now. Probably ranted too much already.
    Cheers,
    Tom
    NYC
    1,656
    Received: 7/0
    14
    Couldnt agree with you more Tom.Its a great way for them to sell tubes-lots of them.Most players just want to plug and play and when they here about the Mesa deal of course they will.Its a great marketing scheme for them.Dont think you ranted too much,or ranted at all.Its just the facts.
    NYC
    1,656
    Received: 7/0
    14
    Tom,I had never read that "white paper",mainly because I never bought into the Mesa bias scheme,either.I just read it and cannot believe the BS he is throwing out there.It's amazing.I own a couple of boogies and I installed bias pots when I changed the first set of tubes in each.It is the only way to go.
    Nov 2006
    3
    0
    question
    Quote Originally Posted by stokes View Post
    How hard is it to install bias pots in a 50/50? I am a novice, but I work with electricians that would be willing to help. Thanks agian for helping with my question.
    NYC
    1,656
    Received: 7/0
    14
    Putting the pot in is not hard,it is just a matter of replacing a resistor with a small cermet pot.If you can read a schematic,there are 2 resistors in that bias supplly in series,one is 47k the other is 68k.The 68k gets replaced with a 100k cermet pot.Get the multi turn pot if you can otherwise the regular cermet will do.Make sure your friend knows what he is doing,as well as setting the bias once the pot is installed.You can find the schem at schematic heaven.com-be aware that there is dangerous,possibly lethal voltages in an amp, if you or your friend do not know where these voltages are in an amp it might be better to get someone who does to do the job.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    31,477
    Received: 1,379/7
    53
    Instead of replacing that resistor with a pot, might I suggest replacing it with a pot and resistor in series. That way no one can turn the pot to zero and kill the bias altogether.
    So instead of 100k pot for 68k, make it a 50k resistor and a 50k pot. That way the minimum resistance is 50k (or whatever value you decide makes a reasonable minimum voltage) with the pot at zero, and then the whole range of the pot is more useful.
    NYC
    1,656
    Received: 7/0
    14
    But if you come across a pair of tubes that need less than the 50k fixed, you are back at square one and have to replace or remove the resistor.If you mount the pot inside there is little chance that someone will turn the pot to zero.I do not in any way say that what Enzo said is not sound advice,it is a safety measure and you cant go wrong being safe.I could be wrong but I think the 47k resistor in series with the pot would be a good enough safety net.If you turn the pot to zero you will have the full 47k.
    Member jak0lantern01's Avatar
    Nov 2006
    28
    0
    So I had my Mesa at an authorized repair shop and the two techs there asked me why I use the Mesa tubes. My reply basically reflected the Mesa line that their tubes are guaranteed and properly biased, yada, yada, yada. The two guys said that it was NOT necessary to use the Mesa tubes, there are others that can be used as well and Mesa is milking my bank account. What's going on here? I mean, can I really just throw some Groove TUbes in or any other brand? Judging by everyone's respone here, I'd say NO. Then again, why would two authorized Mesa repair techs tell me I'm wasting my $$$ on Mesa tubes? I'm a little creeped out by this one, I don't need another catastrophic breakdown of the amp.
    Jun 2006
    Norristown state hospital
    2,128
    Received: 97/1
    15
    You're wasting $$$ because Mesa charges alot for tubes.
    You CAN use any brand, but as stated here they need to be biased.
    Some people change tires and randomly inflate them without checking tire pressure, but we all know a properly inflated tire will last longer, perform better and safer....same with properly biased tubes.
  12. #12
    Nov 2006
    28
    0
    But that's my point, or perhaps I wasn't clear enough. It was indicated that I didn't have to worry about the biasing. That's the part that scares me in their statements. These are the guys who fixed my amp. They didn't replace the tubes with Mesa's, and they sure as all hell didn't do anything to alter the bias. This leads me to a question: what are the negative effects of installing tubes without correctly setting the bias? I do have to admit, the EL34's they installed for me sound damn good, though.
  13. #13
    Jun 2006
    California, USA
    3,554
    Received: 130/0
    Given: 90/1
    16
    My current approach to MB tube replacement:
    I keep tubes in stock with a decent range of pre-tested and graded bias requirements. I can then select a set that works as well (or better) than the Mesa tubes. I still check the bias and make any required repairs, such as replacing burnt screen & hum balance resistors, before I button the amp up. This is the best solution for me and the customer. This doen't take me any more time because all my customers want the amp bench checked anyway. Sometimes they buy an additional spare set of tubes matched to those I install.
    Customer gets a properly biased amp. No circuit mods required so no-one can ever complain that I voided their warranty, screwed up their amp, reduced the resale value etc.
    Customers have brought in MB tubes. They don't all fit in a narrow bias range. See my earlier comments about the color coding.
    Tom
  14. #14
    NYC
    1,656
    Received: 7/0
    14
    As long as your plates arent glowing red or orange you are safe.Dont confuse the normal glow of the heaters with a red plate.The plate is the large gray structure in the tube,it will look like someone hit it with a blow torch if it is running too hot.If it is have the bias set properly or the tube will fry,and may take other components with it.Groove Tubes can safely be used in a Mesa if they are in the #4 to 7 range.If that is what they put in there you should be okay.I dont care for this system,but it is safe.Like Drewl, I like to set the bias for what I think is the best performance.
  15. #15
    Nov 2006
    28
    0
    What about pre-amp tubes?
  16. #16
    Jun 2006
    California, USA
    3,554
    Received: 130/0
    Given: 90/1
    16
    Pre-amp tubes don't require a bias adjustment if that's what you are asking.
    Just use tubes that sound good to you.
    Due to the high gain MB circuit you will need to use good tubes that are low in microphonics in the the front end of the pre-amp.
  17. #17
    Noodle of Reality Steve Conner's Avatar
    Glasgow, Scotland
    7,251
    Received: 13/0
    22
    Be that as it may, when the original bias voltage is altered far enough, it will compensate for the tube's abnormal performance and the correct amount of idle current flow may then be restored. Clearly this is something most repair techs should not attempt.
    Surely Randall Smith meant to say "There's nothing better than an amp with permanently installed cathode resistors brought out to jacks on the chassis for plugging in a voltmeter, and a bias pot for each power tube with a wide range of adjustment too, so you can stick in any old tubes you found at a flea market and let them rip"
  18. #18
    NYC
    1,656
    Received: 7/0
    14
    Yeah, he should have said a lot of things.Mostly he should have kept his mouth shut.I cant believe someone with his background would make some of the statements he made in that paper."Clearly this is something most repair techs should not attempt".That is absolutely absurd.This "paper" was obviously directed towards people who have no idea what goes on in their amps,and scare them into using his tubes and putting amp techs out of business.
  19. #19
    Nov 2006
    28
    0
    In light of the statement everyone is complaining about, shouldn't there really be more issues with Mesa amps? I mean, is everyone really using THEIR tubes or throwing non-Mesa tubes without properly adjusting the bias? Something just doesn't add up here. Plus, there is the reality that two authorized Mesa techs told me don't bother with Mesa tubes, it's all about the name and that's it. As I stated earlier, the non-Mesa tubes they tossed in sound great and haven't yet experienced trouble. Since we're on the subject of tubes, I wanted to get an opinion on how many hours people run their tubes before replacing (Pre and power). I'm sure you're not all waiting for failures before swapping. I average anywhere from 6-8 hours a week at jam-level volumes (I have to hear over the drums and everyone else).
  20. #20
    NYC
    1,656
    Received: 7/0
    14
    A lot of tube suppliers are selling tubes that are tested and graded to fit Mesa's bias range.GT has been doing it for years,in fact Mesa endorses the use of GT's.I have heard that Eurotubes and KCA are doing the same.I would have to think or at least hope the Mesa techs you mentioned are using tubes that fall into the peoper range,in which case you would be safe.I think you can attain better performance out of your tubes if you fine tune the bias.Even if I were inclined to use the Mesa system I would still have to check the bias to see where they were idling,which would just force me to tweak it anyway.
  21. #21
    New Member
    Nov 2008
    1
    0
    How would you bias a Boogie amp? I have a buddy who has one and he doesn't care for the tone and I suggested re-tubing and checking the bias then I remembered as a former MKIII owner I never did bias but I did always use MB tubes.
  22. #22
    Dec 2010
    50
    9
    ive seen a thread about a Bias mod on a 50/50.. but its on another forum.. can i post the link here?
  23. #23
    Dec 2008
    Wernersville, PA
    12,662
    Received: 339/2
    Given: 175/0
    25
    Sure.
    But start a new thread.
  24. #24
    Dec 2010
    50
    9
    orayt!! tnx..
  25. #25
    Dec 2010
    50
    9
    ive seen a thread about a Bias mod on a 50/50.. here it is.. The Boogie Board • View topic - Bias mod on a 50/50 : how to do.. this will surely improve our amps performance and how we are playing guitar..
  1. Mesa Boogie F50
    By Spence in forum Mods & Tweaks
    Last Post: 06-11-2010, 10:31 PM
  2. Any Mesa Boogie techs out there?
    By tonezoneonline in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-18-2006, 02:19 PM
  3. Mesa Boogie 2:one hundred
    By mentale in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-02-2006, 11:53 AM
  4. Mesa Boogie Mark IIC
    By Boulder Bob in forum Guitar Amps
    Last Post: 08-08-2006, 05:27 AM
  5. Mesa/Boogie MarkI Input Jack
    By Kensel in forum Theory & Design
    Last Post: 07-21-2006, 02:54 AM
