What is this component?
  • What is this component?
    Hey guys,
    I've been slowly working through this amp sketching out a schematic as there is none to be found anywhere.
    The tube compliment is:
    6SC7
    6SF5
    6V6GT x 2
    5Y3GT
    On the 6SF5 there is this little component attached from pin5 (plate) directly to ground, can't be more than 3/8" long, looks like a grease zerk. Black in color with a dab of violet and yellow. Leads come out of the side of the body kinda like an orange drop but definitely not out of the ends.
    I can not measure any resistance across it.
    Anyone know what this is and its intended purpose?
    Hi,
    I think it's a small ( = low capacitance, 4,7 or 47 pf, can't tell for sure from the pics ) capacitor sending the highest frequencies from the plate to GND ( low Xc at high frequencies ) to keep the thing from oscillating.
    Hope this helps
    Best regards
    Bob
      Yep, it's a capacitor. A rare tubular type, and by the Yellow/Violet markings it's value is 47pf.
      Now Trending: China has found a way to turn stupidity into money!
        So, on a recap should this be an included replacement or safe to leave in place?
        Any guess to the type? Mica?
          Yes it's a "dog bone" tubular ceramic capacitor. I suggest leaving it alone unless you are sure it is defective.
          Read about them here - http://www.vishay.com/docs/22019/cergenin.pdf
            'Tubular Dogbone' ? Sounds like a farrrrout hip old blues cat from the '70s man ;-] g
              basically an obsolete style from what I've seen. Some have less coating and you can see through the tube, while for others the whole body is coated over. There were some new I've seen that had the same shape but they were apparently huge. Some old resistors have the same "dog bone" structure also.
                Okay, if your going to use Tubular Dogbone for your stage name I get 15%
                I have only encountered these in high frequency designs (way above the audio band)..........
                  What kind of amp is it (make & model)?
                  -tb
                  "If you're the only person I irritate with my choice of words today I'll be surprised" Chuck H.
                    Its this Newcomb G-12
                      Me too, as I was saying, its Capacitive Reactance Xc is very low at higher frequencies and very high at audio frequencies: Xc= 1/(2Pi*F*C) so, at 20 KHz its capacitive Reactance is about 170 KOhms, at 20 Hz we have 170 MOhms, while at 20 MHz it's 170 Ohms ( and we're waaaay into the RF "realm" ).
                      This is why my best guess is that capacitor is there to keep that stage from unwanted oscillation, as it's a route to GND for all the frequencies above the audible range.
                      Hope this helps
                      Best regards
                      Bob
                        Tubular Dogbone
                        [QUOTE=gbono;91441]Okay, if your going to use Tubular Dogbone for your stage name I get 15%
