I am having a problems with a powered sub woofer, a Porficient S8. The speaker was making a loud hum and not playing music. When I powered it on without any load it smoked a small 4.7pF cap. I replaced the cap and the TDA7293 amp. now it works but doesn't have much power. Any ideas?
Powered Sub Woofer
sub amp fault
Welcome to forum.
Now before you change any more part's do some voltage checks and this will save you some time and help locate your faulty part quicker!
what is the volt reading at the out put end? do some signal tracing to track weak power drops.
you should invest in a decent digital multi meter.
Sounds like the old output chip was making DC and putting it on the speaker. COnnect the system to a different speaker for test. YO(u may have damaged the original speaker.Education is what you're left with after you have forgotten what you have learned.
