Peavey Vavleking footswitch mod
  • Peavey Vavleking footswitch mod
    Hey,
    Anyone know a mod for the Peavey footswitch so that it doesn't cut the signal when you click the switch to change channels?
    Thanks Alot
    The footswitch is just a button. It does the same thing with the panel button.
    There is a momentary mute so no noises come out during channel switching.
    You could try removing C130, the timing cap. If that doesn;t help enough, then remove Q101 to eliminate the process entirely.
      Ok, thanks alot for the help
