I drew the schematic from the PCB. The tone stack and PI had me going in circles so if you see anything weird on there let me know. The input switching on the Cliff jack is a bit funky too , some bits are on the metal chassis and others are grounded to the PS.
That's how it is wired , I've just checked it . In "Triode" mode there is 470 Ohms between pins 7 & 9. In "Pentode" mode pin 9 goes to the screen supply via the 470R.
Are you sure the master volume is correctly drawn? It doesn't look like a normal PPIMV. If it is correct then can anyone explain why it is done that way? If VR1 was 470K and C15 & C30 not present then it would make more sense.
