Chassis up and running , have not completed the cab yet. Sounds wonderful. The soldering around the bias supply is a bit messy as I had to do lots of fudging around with resistors to get the voltages right. I had to build a bias supply off of a rectifier pin socket as the PT I used did not have a tap for one, was a bit of a chore but it all worked out in the end. I may clean it up a bit later but as it's running perfectly fine I may just leave it be.
I am going to play it for a while with different speakers to see if I want to go with a 10 or a 12 inch speaker.
Here are a few pictures.
Alby.
http://photoshare.shaw.ca/messages/v...904/page/1/15/
Alby.
