Results 1 to 15 of 15
Thread: The hell with soldering
    May 2007
    68
    13
    Read a few threads on here lately about soldering problems, mostly from posters who are just into pickup making.
    I came up with this idea a while back when i started making pickups, maybe this would help somebody out, it requires no soldering at the pickup.
    I bought a few packets of compression springs 5/32" dia. and 1/4"dia, length 3", cut them up into short pieces and inserted two into the baseplate of the pickup and four into a humbucker test pickup, reinforcing them with a little superglue.
    I then pulled the springs back slightly and slipped in the start and end magnet wires.
    I pressed lightly down on each spring (to get through the insulation) until i got a reading from my meter.
    All was left was to hook up the switch control wires the same way to the springs underneath the baseplate.
    Supporting Member John_H's Avatar
    Jul 2006
    Las Vegas Nevada
    1,131
    Received: 264/1
    Given: 255/0
    14
    Here's my Epi Les Paul that I use for a test/demo guitar. I can substitute pickups without soldering, but I wanted to do the same for capacitors. Compression springs should work great. Thanks for the cool idea!
    Pickup Maker David Schwab's Avatar
    Staten Island, NY
    10,950
    Received: 7/0
    Given: 6/0
    27
    I have a bass with alligator clips like that. I also always have a set of alligator clips connected to a 1/4" jack handy.
    It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. Albert Einstein
    May 2007
    68
    13
    I forgot to add this drawing to my earlier post.
    Staten Island, NY
    10,950
    Received: 7/0
    Given: 6/0
    27
    So what happens in a few years when the spring and the end of the magnet wire start to oxidize?
    May 2007
    68
    13
    Quote Originally Posted by David Schwab View Post
    Never got to that stage, what do you think would do the job?
    May 2007
    68
    13
    Quote Originally Posted by John_H View Post
    Nice setup, i haven`t seen the controls cavity on a Les Paul up to now, not much room in there.
    Hope that idea of mine works for you.
    Staten Island, NY
    10,950
    Received: 7/0
    Given: 6/0
    27
    Quote Originally Posted by Alabam View Post
    Soldering.
    It's a cool idea for the wires outside the pickup though.
    Dec 2008
    520
    Received: 8/0
    11
    I built a bench "mule" for doing R & D work on pickups. It's essentially a crude neck mounted on a wood base resembling the body, with strings, bridge, etc., matching the geometry of my production basses. It's designed so I can quickly swap pickups in and out. Built on to it is a box with my normal pots and passive wiring harness. I used standard electronics lab type binding posts on the box for the hookups. Binding posts will clamp on the 22 ga leads, or directly on the magnet wire if needed. I also brought the tone caps out to binding posts, so they can be quickly swapped during testing.
    Staten Island, NY
    10,950
    Received: 7/0
    Given: 6/0
    27
    At some point I have to make a pickup testing platform.
    I'm currently using this bass, but it's going to get renovated and put back in service soon, so I need a bench mule.
    May 2007
    68
    13
    Thumbs down
    Soldering.
    A kick up the butt and a pat on the back, nice one David, ROFL.
    Regarding those tiny round coils we talked about a short while ago and the pic you supplied.
    I noticed they were all wound separately and i wondered if you wound these yourself.
    I wind them in series on the winding rod, three or four bobbins at a time which leaves me with just the start and end wires, have you ever tried this method?
    The plastic bobbins I ground down to the right diameter so they fit right into Strat covers.
    I got into this circular type of winding because i it seemed to me you got a closer contact to the magnet source than the standard rectangular wind, also it was a faster and smoother operation, and no need for all these gadgets i read about on the "Tools and Coil winding gear" forum.
    Cheers.
    Sam.
  12. #12
    May 2007
    68
    13
    Soldering.
    How did that thumbs down icon get there, must have clinked on it by mistake, sorry about that.
  13. #13
    Staten Island, NY
    10,950
    Received: 7/0
    Given: 6/0
    27
  14. #14
    Mar 2007
    34
    0
    Here was my original Neo Jazz solderless connection system. It works well but it was a pain for me to do and most folks seem to be able to solder in a pickup or pay the guy at Guitar Center to do it so I dropped it on later models.
    Ever Learning
    Clint Searcy
    www.searcystringworks.com
  15. #15
    Staten Island, NY
    10,950
    Received: 7/0
    Given: 6/0
    27
    I was using those same connectors on the preamps I used to use with my low z pickups. The one problem was it was for heavier gage wire. They do make smaller ones, but I was getting them at Radio Shack at the time.
    If you want to talk about a REAL pain... make some of those multi pin connectors like on the bottom of EMG pickups!
  1. Replies: 9
    Last Post: 02-24-2011, 04:21 AM
  2. Help! Soldering on a new board
    By Rigormortis in forum Build Your Amp
    Last Post: 01-14-2009, 04:51 AM
  3. soldering video
    By scole in forum Theory & Design
    Last Post: 12-22-2008, 10:20 PM
  4. Soldering Technique
    By rymac in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-07-2008, 10:41 PM
  5. Rod Magnet Hell....
    By Stan H in forum Pickup Makers
    Last Post: 08-02-2008, 02:21 AM
