Results 1 to 5 of 5
Thread: 1x12 from large a pipe
    Senior Member Guitarist's Avatar
    Jul 2006
    506
    That green pipe they use for construction would work great for a speaker cab. If the top was cut at an angle it would self-balance but if then you have an oval. Otherwise add a long pice of dowel is a forward lean support. Good angles would be a plus so you can hear the amp at its best. I made a model - to demonstrate this to my picky bass player bud - from the inside of a toilet paper roll.
    To size, just cut it with a band saw. Screw mounts could be wood pieces Gorilla glued to the inside.
    A really wide pipe would give large internal volume with minimal height. How much would equal a cab 16" deep (the optimum in my opinion) I don't know. Maybe there is an online calculator someplace.
    Easy to paint, and the raw speaker would look cool but exposed to harm.
    Why are we using 12' speakers all the time?
    Supporting Member
    Apr 2007
    1,027
    Received: 14/0
    Given: 4/0
    Saw one made from column form cardboard!
    Many years ago in Speaker Builder magazine, a bass player used the round cardboard used to form concrete to build a cabinet. Used a 15 EV firing down into the tube, figured the volume needed for the height of the thing, and the rear of the speaker radiated 360 degrees. Seems he had a baffle at the top(rear) of the driver. Said he gigged with it a lot, and worked great for bass,(non-directional anyway). I always wanted to try one but never did.
    Aug 2008
    michigan
    68
    Amp guys will build a cab out of just about anything!! Doug Hoffman built a GA5 into a plastic electrical box.
    Senior Member Regis's Avatar
    Atlanta
    524
    Received: 1/0
    Quote Originally Posted by pila View Post
    I've built attenuators in gas cans, cigar boxes, and coffee cans.
    Aug 2008
    michigan
    68
  1. tsl100-f3 blew-large 330uf cabs are discolored
    By wyomingrocks in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-16-2010, 09:59 AM
  2. Using large value screen resistors w/ bypass caps
    By Chrome Dinette in forum Tubes (Valves)
    Last Post: 07-19-2009, 06:21 PM
  3. Any large retailers still sell fuses???
    By ctcpete in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-27-2009, 05:29 PM
  4. Best/worst large manufacturers?
    By Euthymia in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-14-2007, 04:36 AM
  5. Pipe dream?
    By msclford in forum Music Electronics
    Last Post: 12-29-2006, 03:31 AM
