As I'm sure all y'all who have performed the 2 to 3-prong power cords operation know, the old strain relief never works with the new, fatter cord. I'm curious what everybody's preferred way of dealing with this is. When it was my amp or it was something that didn't have much vintage value, I've reamed or drilled out the hole to use a larger strain relief. A few times when the amp did have some vintage value (or I just wanted to torture myself) I've cut away a bunch of the plastic the strain relief to accomodate the larger cord diameter. I've found though that in some cases the new cord is just too big for this to work. I've also heard of using rubber grommits and zip ties around the cable on either side to keep the cable from pushing in or pulling out.
I suppose one other thing to try would be smaller cords. Most hardware store cords are 16g or 14g when I'm sure 18g would be fine for most amps.
