Peavey Renown 400 saturation mod? Enzo?
  • Peavey Renown 400 saturation mod? Enzo?
    I was wondering if it is possible to make the saturation/distortion foot switchable?? Enzo?? Is it possible to just interrupt the signal ,either pre or post the saturation pot and wire in a 1/4 jack?? Does anyone have the wiring diagram for the original footswitch ? It's a 6 pin din plug.
    Thanks in advance...
    The footswitch wiring is on the amp schematic.
    I don;t know what you mean by making the saturation switchable. The channels already switch. Saturation is just an overdrive control, it isn't off/on, it is a variable control.
      Thanks alot for the schematic. I was trying to see if there was a way to make the saturation be on/off. A way to make it more like clean channel,lead channel with or with out distortion. A way to interupt the signal before the saturation circuit ? and then back ? possible??
      thanks again
        I would like to work like the reverb does, variable but also on or off...???
