It has been said that NFB lowers the output impedance of an amplifier, and the more NFB there is, the more the speaker is damped (from the lower output impedance) and the less effect the resonance of the speaker has on the sound (tighter bass).
It appears correct that the more NFB there is, the less effect the resonance of the speaker has on the sound (tighter bass), but not because NFB reduces the output impedance of the amplifier. It is because NFB reduces the output voltage of the amplifier at the resonant frequency of the speaker.
What is the output impedance of an amplifier rated at 8 ohms for example?
Suppose the primary inductance of the OT is 5 H. (5 H might be in the ballpark. See http://www.hammondmfg.com/125a.htm)
The inductive reactance of the primary at 100 Hz is about 3.15 Kohm. (2 * pi * 100 * 5).
Suppose the plate resistance of the pentode output stage is 1 Mohm. (1 Mohm might be in the ballpark. See http://www.geocities.com/tube_theory/Pentode.htm)
Suppose the impedance ratio of the OT is 400 to 1. (400 to 1 might be in the ballpark. See http://www.transcendentsound.com/amp..._impedance.htm)
The output impedance of the amplifier at 100 Hz is about 8 ohms. (3.15 Kohm / 400) (Vector sum of 1 Mohm and 3.15 Kohm is approximately 3.15 Kohm.). (The output impedance increases as frequency increases.)
Suppose the resonant frequency of the speaker is 100 Hz. (100 Hz might be in the ballpark. See http://www.churchsoundcheck.com/imp1.html)
Suppose 1000 Hz sine wave is input to the amp. The output impedance of the amplifier is about 31.4 Kohm, and the impedance of the speaker is about 6 ohms. Since the speaker impedance is less than the amplifier output impedance, the speaker is loading the amp pretty well.
Suppose there is a certain amount of NFB. The signal across the speaker at 1000 Hz will be a certain amount.
Suppose the frequency to the amp is reduced to 100 Hz while its input level is held constant. (Assume the preamp and splitter frequency response is flat.)
The impedance of the speaker is now about 18 ohm while the output impedance of the amplifier is 8 ohms.
The speaker is no longer loading the amplifier as much as it was before, and the output voltage of the amplifier starts to increase.
The increasing output voltage causes more negative feedback through the NFB loop which tends to reduce the output voltage.
The effect of the resonance has been reduced because the output voltage of the amplifier has been reduced by the NFB. The more NFB, the more the effect of the resonance is reduced, but the output impedance of the amplifier does not change when NFB changes, and the damping of the speaker does not change when NFB changes.
