cnc winder controller board
  • pickup winding mode
    wind direction
    with buttons 4 & 5 select wind direction
    with button 3 confirm and skip to turns setting
    with button 2 return to operating mode selection
    turns setting
    with buttons 4 & 5 select turns value with +1 or -1 steps
    with buttons 6 & 7 select turns value with +100 or -100 steps
    with button 3 confirm and skip to automatic height bobbin measuring (traverse movement between switches.... controller needs for TPL calculating)
    height measuring
    controller perform a measuring of traverse movement between limit switches and show value... you can:
    with button 1 restart measuring
    with buttons 4 & 5 move traverse.... useful if you want adjust limit switch position
    with button 3 confirm and skip to traverse mode selection
    traverse mode
    there are 3 mode for traverse movement:
    single pitch: enter a pitch for all layers in your pickup
    alternate pitch: you can enter from 2 to 10 pitch values and traverse rotate them in pickup winding layers
    random pitch: you enter min and max values.... traverse rotate random values between min and max
    with buttons 4 & 5 select mode
    .......my gaussmeter project..... ........
    .......first pickup with my cnc winder........
    .... NEW cnc pickup winder user manual.....
    • if you select single pitch
      with buttons 4 & 5 select pitch value with +1 or -1 steps
      with buttons 6 & 7 select pitch value with +10 or -10 steps
      with button 3 confirm and skip to tensioner setting
      ______________________________________________________
      if you select alternate pitch
      enter number of pitch values you want rotate in layers
      with buttons 4 & 5 select number of values +1 or -1 steps
      with button 3 confirm and skip to pitch values setting
      select values like in "single pitch" but for n times
      if you select random pitch
      select values like in "single pitch" but for min and max
      • tensioner value
        display show default value
        with buttons 4 & 5 modify tensioner value with +1 or -1 steps
        with buttons 6 & 7 modify tensioner value with +100 or -100 steps
        with button 3 confirm and skip to speed setting
        with button 1 power on/off tensioner (useful for test)
        speed value
        display show default speed
        with buttons 6 & 7 modify speed value with +200 or -200 steps
        with button 3 confirm and skip to "ready to start"
        ready to start.... and run
        with buttons 1 start-pause winding (go or stop with ac-deceleration)
        with button 2 emergency stop winding (without deceleration) and if you push again return to operating mode selection
        during winding display show turns - tpl and tensioner value.....
        • I can't wait until this is all figured out so I can start buying parts!
          Glad I didn't start on my new winder yet.
          • Elepro,
            A helpful tip to avoid confusion (ours) regarding the term "Height Adjustment" and "Height Measuring".
            It would be better named "Traverse Width" and "Traverse Measuring" because we are speaking of the traverse's traveling dimension rather than the fixed dimension of the bobbin. In practice a winder often sets the traverse end-guards (end guides?) narrower than the bobbin because the wire pushes out toward the edges by nature during winding, so we're really not adjusting bobbin height or measuring bobbin height but traverse the user desires to span you see?.
            Also I see there is no absolute turns-count method. We are counting steps we tell the motor to turn and doing some math. Myself and I'm sure others here would prefer to know absolute turns the bobbin made when winding. Using an optic or other sensor on the bobbin holder or shaft. The problem I can forsee is not having a absolute count is that when we add a pulley system to raise the RPM then we are at the mercy of having exactly matching pulleys and zero belt slip/stretch. After 5000 turns or more error can add up.
            It should be better to consider implementing in your microcontroller to sense feedback from the bobbin holder or shaft by a sensor giving actual turns count back to your PIC then any mis-match in shaft/linkage/construction would be accounted for and automatically zero'd out.
            (I have implemented these sensors before: Winder v2.0)
            -Brad
            ClassicAmplification.com
            • Originally posted by RedHouse View Post
              Elepro,
              If we use the cogged pulleys and belts with proper tension there will be no lost turns.
                Elepro,
                yes you right.... these name are better...... but
                yes... with hands... but with automatic traverse you can set limit switches position perfectly to have traverse travel = height bobbin and wire go always inside flatworks....
                turns shown are always perfect... no errors...you can start-pause-restart-pause as you want and turns shown are always right.... and when you arrive at last turn faceplate stops with perfect same angulation of start.... we are speaking of pulley and belt with teeth.... no slip or stretch
                you can have small error (fraction of turn) only if you use emergency stop, because stepper break system can't stop immediately the motor inertia ....
                about stepper and feedback system (closed loop): my cnc milling machine make a complete body or a neck without any kind of feedback..... then really doesn't need for a winder...
                • heck, I'd also be interested in building a winder based on this design. These builds have inspired me to further my next-to-zero understanding of PCB design. You guys rawk...
                  • Originally posted by -Elepro- View Post
                    I think you mean width of the bobbin where I've bolded.
                    I've followed this thread with interest, as I'm actually presently still developing my own CNC winder - honing the traversal calculations aspect of it tonight as it goes! (don't worry Elepro...I'm not going to be competing with you - mine uses a CNC host - Mach 3!).
                    For those who haven't dabbled - there is much much more to the 'input parameters' than you'd initially imagine - & yes, with CNC winders, you can set the limit switches so the wire always stays inside the bobbin edges...but you'll end up with wire 'banked' at each end of the bobbin...so you need to set the left & right traverse 'extremeties' shorter than the total available winding width of the bobbin (I don't use switches - my program automatically takes account of this - for example, let's say a bobbin has 10mm of potential bobbin winding width. If you try to get your CNC winder to use the full 10mm it'll be uneven, so the winder should only use say 9.6mm (obviously these aren't real world figures...it would depend on wire gauge - I'm just trying to illustrate a point).
                    So for a seemingly simple input parameter as 'bobbin width', assuming limit switches aren't in use, you either have to ...
                    1 To manually inputa 'trimmed' bobbin width, taking a stab at what you think will end in a neat wind (trial & error).
                    2. Have your CNC winder program atomatically make this calculation for you 'behind the scenes' so to speak. (which still needs trial & error, but at least one you've honed it, it saves a little bit of calculating)
                    Then there's wire size - the widths quoted when you buy wire, doesn't inculde the enamel coating ...so I normally add about 10% on. This is quite a key paramater, as obviously over several thousand winds, the margin for error is big!
                    & on it goes...I'm sure Elepro has it all covered, but I'm now on my third CNC winder build (first was a pic driven CNC winder, my second was 'Mach3 hosted' using someone else's winding program....albeit needing some debugging by me.. this 3rd build is my own effort!).
                    I happen to enjoy the challenge, but trust me...this is all brainache & deeply time consuming - so far better to let Elepro do the legwork for you & chuck him some sheckles for his effort! Just realise that the end product will still need a fair amount of initial trial & error for your own winding needs.
                    • Originally posted by peskywinnets View Post
                      ...For those who haven't dabbled - there is much much more to the 'input parameters' than you'd initially imagine...
                      Yes, Elepro is also kindling my spirit too. I'm fairly experienced in C, C++, C#, VB, and VBScript so I'm familiar with programming methods. I have pondered having a look at PIC programming but spare time is not this time.
                      (I also have 4 years in UI testing that is why I tend to suggest usability things)
                      -Brad
                      • I really like the manually adjusted limit switches. It's intuitive and we are all used to pushing our goal-post thingies around to get the bobbins filled correctly.
                        • just arrived.... with a spare belt too
                          pulley 10 teeth 0.2"pitch
                          pulley 20 teeth 0.2"pitch
                          belts 110xl (11" lenght 0.2"pitch 55 teeth)
                          distance between center of pulleys will be 100mm...
                          • Originally posted by David King View Post
                            Me too.
                              Me three
                              -Brad
                                Would those pulleys fit the stepper motors you recommended in post #138 ? I ask that because I ordered a couple of those Lin Engineering 4218L-01-11 bipolar stepper motors.
                                If yes, where did you source those?.
                                -Brad
