Looking for a single triode tremolo circuit for a cathode biased princeton reverb
  • Looking for a single triode tremolo circuit for a cathode biased princeton reverb
    The title says it all... :-)
    I'm preparing a new build.
    Based on the princeton reverb, but cathode biased.
    Cathode bias and the existing tremolo in the princeton reverb won't work together, so i'm looking for a single triode tremolo circuit for this build.
    Maybe you can point me in a direction, because i'm all out of ideas myself...
    Thx!
    GA17RVT trem? You may want to add an intensity pot
      another option
      Here's another option to throw in the mix.
      With respect, Tubenit
      http://www.schematicheaven.com/voxam...dge_reverb.pdf
        I have been reading up on this cambridge circuit and the vox pacemaker is very similar. But the tremolo circuit is a little different.
        Depth is connected to a capacitor first in the cambridge, but to a resistor first in the pacemaker.
        The osilator cap arrangement is connected to ground in different ways...
        Which of both would you prefer?
        (I found the pacemaker schematic @ schematicheaven)
        thx!
          Successful mod - cathode biased with vibrato
          Hey folks thanks for the tips. I was modifying a 70's PR to be cathode biased and successfully incorporated a modified version of the pacemaker vibrato. I got the best results by using a 1 meg pot for the intensity, and removed the 680K resistor. I only use a .1 cap before the plate and it seemed to work the best.
          Thanks!
          Max
