Peavey Bandit 65 - Problem in volume knob
  • Peavey Bandit 65 - Problem in volume knob
    I´ve recently got a Peavey Bandit 65, 2nd hand .
    Althoug I tried before buying it, it was just when I got home that I noticed that the volume knob doesn´t operate in a progessive way : the slightest turn of the knob (even close to the 0 mark) gives you a high volume response. Would this be something easy to repair ?
    Thks
    It seems to be a defective Potentiometer. If you can find the same type and lug configuation of the same value, it would be a simple desolder/R&R job.
    Now Trending: China has found a way to turn stupidity into money!
      SHould be easy enough to get the exact part from Peavey.
        Some info here.....
        Peavey.com :: Frequently Asked Questions
