I am building a Sloclone on a fender twin reverb. The PT is original but the OT is an upgrade. The schematic of the SLo100 has a 25k bias pot. What wattage rating should I use?
Slo-100
The SF doesnt have a bias adjustment,it is a bias "balance" that divides a fixed amount of neg.volts to the 2 sides of the output.Better to rewire this set up like the Backface,which is a true bias adjustment.As long as the 10k pot gives you enough latitude to adjust the bias it will be okay.
