I'm finishing up my ts-5 rehousing/mod project, finally got my drill bit today, put it all together, and when I plugged it in, nothing. I'm powering it off of my boss tuner, and it worked fine until I fastened the DC jack to the enclosure. I took out only the DC jack from the enclosure, and it powers up and plays fine. What should I do? I wired it up the way that the attached diagram is wired. Also, when the jack is in the enclosure, it lets signal through when in bypass mode, but not in active mode. Pedal is wired for true bypass.
Stompbox power ?
