Lock washers on jacks
  • Lock washers on jacks
    Is it a good idea to use lock washers on jacks and pots??
    a
    If your chassis is stainless steel it is. Ally is a bit softer and it is easier to 'dig' the nuts in just by making them good and tight (without stripping them)
      Star washers
      Ok so on the 5E3 type chassis that is using the brass ground plate, would one use the star washers between the brass plate and the inside of the chassis??
      aneg
        Yep spring washers help with the hold on brass
          I wouldn't think you'd sandwich anything between the brass plate and the chassis.
            No washers needed.
            You mount the brass plate under the bushings of the Switchcraft jacks and between them and the chrome chassis.
            Tighten the bushing nuts hard enough for the jack to "dig" into the brass as you very very slightly twist the jack to get it to "seat" into the brass.
            Also, don't forget this tip:
            Always solder the ground wires onto the brass plate before mounting this stuff. If you don't do it first and mount the assembly to the chassis, it's a good bet you'll never get the brass and ground wires hot enough to flow solder and that is all there is to it.
            Bruce
            Mission Amps
            Denver, CO. 80022
            www.missionamps.com
            303-955-2412
              All my tweed amp chassis are chrome plated mild steel and all my kits come with a nice brass ground plate.
              Bruce
              Mission Amps
              Denver, CO. 80022
              www.missionamps.com
              303-955-2412
