Fender Blues Deluxe Components Source
  • Fender Blues Deluxe Components Source
    I have a '96 Blues Deluxe and am in need of some components.
    Power switch DPST panel mount Carling Toggle Fender #036570
    R85, R86 5w 10% 470 ohm res
    CR 22,23 1N5353B Zeners
    CF 1/4W 5% 100K res
    I would like to be able to order all from one source and am asking if someone can give me a source for these parts.
    John
    Mouser Electronics - Electronic Component Distributor
    Allied Electronics - Electronic Components Distribution
    DigiKey Corp. | Electronic Components Distributor | United States Home Page
    All the parts on your list are generic, so most parts houses could cover it.
      re:supplier
      Thanks for your reply Enzo. I found a place last night called Newark. They were very helpful.
      For those power resistors, I ended up ordering a couple of Dale aluminum housed 500ohm which I plan to mount to the cassis side and wire in. Do you think 500 is close enough?
      Power Resistor
      Power Rating:50W
      Resistance:500ohm
      Resistance Tolerance:± 1%
      Series:RH
      Operating Temperature Range:-55°C to +250°C
      Resistor Element Material:Ceramic
      Temperature Coefficient:± 20ppm
        Newsong,
        Dude if those are sand block power resitors,I'll send ya a couple no problem.Those Dale's are not the way to go,, in my opinion anyway..PM me if ya need them..
        DW
          They are the dropping resistors in the power supply circuit and typically get so hot due to the poor design that they are constantly needing maitenance.
          It is my idea to get them off the board and thereby save the constant resoldering etc.
            OK bro,
            Just thought I'd offer ya some thats all..
            DW
