HI everyone this is first post, just ordered some pickups kits from stewmac my question is should i get a polarity tester or use a compass ,also why can't i just use a small magnet like one of those for picking up nut n bolts on a little telescopic handle, will touching the a alnico polepeice with the magnet change your pickups tone or have any effect on pickup
magnet polarity tester ?
I have one of those Stew-Mac checkers, just because it's handy and I didn't have a compass, but either one will work.
You shouldn't touch another magnet to your pole pieces, and don't get the Stew-Mac polarity checker too close to alnico magnets either. I hold it a few inches away from the pickup.
You can also just use a magnet with one side marked, and once again don't touch it to your poles.
I'd go with the Stew-Mac checker or a compass.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
I bought one from mcmaster carr that works well. Also if you end up getting a Gauss Meter it has a polarity tester built right in. Not a must for a pickup builder, but it sure is handy.
Gaussmeter - GM200A
Would Lenz's Law work? Basically just a coil of wire and a volt meter?
(Second frame down) HyperPhysics
If velocity is always the same direction, and the meter is always hooked up in the same direction, then you should be able to determine the polarity of the magnet.-Mike
Originally posted by defaced View PostWould Lenz's Law work? Basically just a coil of wire and a volt meter?
But a compass is simpler.
The absolute simplest is to put the magnet on a piece of wood or a little boat floating in a bowl of water, and wait for it to orient itself to the Earth's magnetic field. This is how the Chinese built the original magnetic compasses.
if you use a compass.... ot the little boat ..... remember that Earth's magnetic field has north magnetic pole at south geographic pole....
bye.......my gaussmeter project..... ........
.......first pickup with my cnc winder........
.... NEW cnc pickup winder user manual.....
Originally posted by -Elepro- View Postif you use a compass.... or the little boat ..... remember that Earth's magnetic field has north magnetic pole at south geographic pole....
Compasses can sometimes be a bad idea because the needles in them can pretty easily be remagnetized by a strong magnet without you realizing it. I did this with some neo magnets, then realized later the North side of the needle was point Southhttp://www.SDpickups.com
Stephens Design Pickups
I've got the Schatten polarity tester and don't know how I ever did without it. I hate that nagging feeling that I put the bar magnet in the wrong way. The tester tells me right away just by putting it near the slugs or screws.
It also reassures me that I didn't glue a rod magnet in upside down...
I use the Stew Mac polarity tester, which I find much handier than a compass.int main(void) {return 0;} /* no bugs, lean, portable & scalable... */
www.ozbassforum.com
Get the SM tester, it is worth it. I use it when assembling the pickup and I also use it to double check the polarity just before packaging them up.
I would actually buy a couple to keep around.
Originally posted by Zhangliqun View PostI've got the Schatten polarity tester and don't know how I ever did without it. I hate that nagging feeling that I put the bar magnet in the wrong way. The tester tells me right away just by putting it near the slugs or screws.
In fact I liked that little tester so much I bought a second one, now I can have one on my bench where it belongs, and take the other with me when I go out to do stuff away from my shop.
I use the Schatten tester, AND, mark them with a Sharpie! I hate putting the magnet in backwards.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by RedHouse View PostIn fact I liked that little tester so much I bought a second one, now I can have one on my bench where it belongs, and take the other with me when I go out to do stuff away from my shop.
