Results 1 to 16 of 16
Thread: Unused 5v PT winding
    Jul 2009
    38
    0
    What should I do with the unused 5v winding on a PT I will be using in a project? None of the tubes will need a filament voltage of 5V.
    Supporting Member txstrat's Avatar
    Mar 2008
    Germany
    1,262
    13
    If the winding has cables I'd tape them up and fix 'em somewhere with a cable tie. If there are no cables - don't mind the winding.
    Jul 2009
    38
    0
    Just leave the circuit open, cut the ends off heat shrink em and tie them back?
    Mar 2008
    Germany
    1,262
    13
    Sort of, yes. You don't need to cut off the ends - you might wanna use the winding later (for a different project).
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    31,602
    Received: 1,498/7
    54
    I hope he meant cut off the exposed ends - the stripped little bit at the ends.
    Secure the wires and protect the ends - that's all. I prefer to solder them to empty terminal strip lugs myself.
    Jul 2009
    38
    0
    Yea, I just meant cut off the exposed ends of the wires.
    Old Timer tedmich's Avatar
    Apr 2008
    Sonoma CA
    3,270
    Received: 149/2
    Given: 65/2
    15
    5vdc relays? An awesome LED lightshow?
    50 of these:
    FLASHING RED, GREEN, BLUE LED | AllElectronics.com
    Noodle of Reality Steve Conner's Avatar
    Glasgow, Scotland
    7,251
    Received: 13/0
    23
    Voltage doubler and a 9v regulator to power your stomp boxes?
    Old Timer Gtr_tech's Avatar
    Nov 2007
    Owosso, Mi
    1,616
    13
    How about a doubler and regulators to pwr op amps for active EQ?
    Near Dallas Texas
    3,489
    Received: 158/0
    Given: 95/1
    18
    In one of his books, Tonnes of Tone, Kevin O'Connor uses the 5V winding to make an unregulated 6VDC power supply for preamp tubes. Real simple, 4 diodes and a cap, 2200uF if IRC.
    Junior Member
    Jul 2009
    12
    0
    Quote Originally Posted by Steve Conner View Post
    Quote Originally Posted by tedmich View Post
    you could put the led's behind the tubes so that they make the amp look as if the tubes are actually doing something. (I swear I remember seeing something like this on a Crate Blue Doodoo or a similar amp?)
    I like both of your ideas better than mine:
    remove the bell of the xformer, cut the leads way up in that and then seal them individually with heashrink. Looks clean, and keeps them out of harms way.
  12. #12
    Apr 2008
    Sonoma CA
    3,270
    Received: 149/2
    Given: 65/2
    15
    Quote Originally Posted by crisisat22 View Post
    Yes Crate does this, as does Engl, and some others...as with most things, PV did it first with their Ultra. I get nice (cheap, $1.50) ceramic sockets which have a through hole that fits a 3mm LED perfectly, which I'll use; not as visible as behind the tube but cleaner
  13. #13
    Jul 2009
    38
    0
    LED's
    Are there really any 5v LED's? I thought the 5v rating was the max forward voltage for the LED. I like the LED idea as well as using an LED for the power indicator. I saw one thread on another forum about a guy that used a red/green LED to indicate then the mains were on and when the standby was on. Sounds like an interesting application for the 5V winding.
  14. #14
    Apr 2008
    Sonoma CA
    3,270
    Received: 149/2
    Given: 65/2
    15
    Quote Originally Posted by Rockn View Post
    There are LEDs with built in series resistors to run on 5v, but people usually add there own series resistors, see herehttp://www.csgnetwork.com/ledsingresistancecalc.html
    LED series parallel array wizard
    LEDs do have a variety of forward voltages:
    1.8->4.5v, see:
    Light Emitting Diodes (LEDs)
    on AC you only get 1/2 cycle, but its usually AOK
  15. #15
    Jul 2009
    38
    0
    5v LED
    Would putting a bridge rectifier in there work? Not sure what the voltage would be out of the bridge. Maybe I will use the Duncan PS designer to see what it will look like.
  16. #16
    Apr 2008
    Sonoma CA
    3,270
    Received: 149/2
    Given: 65/2
    15
    try the 1N5822, its a schottky and drops less voltage
    this circuit would give 5VDC before the reg with 5VAC in
  1. Unused triode
    By Sir Cuitous in forum Theory & Design
    Last Post: 06-02-2009, 04:15 AM
  2. Replies: 15
    Last Post: 12-17-2008, 05:12 AM
  3. unused 12AX7 triode - ground unused pins?
    By HTH in forum Theory & Design
    Last Post: 06-07-2008, 12:23 AM
  4. Unused 1/2 -12ax7
    By studioit in forum Theory & Design
    Last Post: 10-01-2007, 04:36 AM
