I just bought two of these little guys, and I gotta say they sound pretty darn good. But..... was wondering what I could do to clean one up. Meaning, have no breakup at a cranked level.
Epiphone Valve junior
Rip the guts out and replace them with the guts of a UL Twin?
Seriously, how are you going to get a big clean sound with only 3 watts available? I think about all you could do is reduce coupling capacitors to cut the bass and give the illusion of more power."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
Do you really think a Twin would fit in there? Might be a little cramped. Perhaps if we left out the reverb, that should be a space saver.Education is what you're left with after you have forgotten what you have learned.
If you go over to 18watt.com there is a very long thread about the VJ. It seems to be a favourite topic there. The thread is months old and has over 2K of posts. I can't be bothered since I wasn't there at the beginning and have never heard or seen one of these amps. There go your holidays.
In order to save your brain, a page twds end in the 18w thread uses this link as a summary of the basic mods: http://forums.birdsandmoons.com/foru...ad.php?t=32385
hope that helps, Captain.
Any lower gain pre-amp valve will clean up the signal going into the output tube (but then there goes your typical champy sound)Building a better world (one tube amp at a time)
Originally posted by Rayme View PostResearch shows I should be able to swap these tubes for the 12AX7 in my Epipy Jr..
5751.... Very nice.. use one in my vj five watter.
12AU7... clean only.. nice for low vol. practice. you'll need pedals.
6681.. never tried.
ECC83.... stock tube.
CV492.. never tried.
12AV7.. never tried
12AT7 ... 30% less gain than the 12AX7
Any comments???? Thanks, Rayme
good platform!
Latest five watt build.
He'll run a 12AT7 preamp tube.
standby
power
gain pot
gain switch
tone
volume
preamp out
power amp in
single input, but I often do hi/lo input
rear fuse holder
marshallized board
new OT
custom panel
gonna use different knobs.. just had these on for the pic
