Roland Cub 60 pwr xfmr replacement
  • Roland Cub 60 pwr xfmr replacement
    Hello all,
    First post and already I'm needy...
    I have a Roland Cube 60 that I want to take with me from the US to my job in Ukraine. I'd like to not have to use a seperate step up transformer for power so I'd like to set it up to run on the local Ukrainian 240v/50hz power. Does anyone know if the transformer in the cube 60 can be pin switched, or does it need to be swapped out? If swapped out where would I get a proper transformer for 240v/50 hz?
    Thanks all.
    Wayne
    The Cube 60D uses different transformers for 120V and 240V
    The 240V transformer is Roland part # SD000469 and retails for $105.00
      You should be able to order the part from a Roland dealer.
