'71 Fender Deluxe reverb question.
  • '71 Fender Deluxe reverb question.
    Ok, I am fixing this amp for a friend. It came in with an "It just won't turn on man!" kind of explanation. It had no rectifier tube, and no bulb in it's indicator light. Is that light wired in series or parallel? Also, does anybody have a schematic for this? I've looked on the web and all I find are numbers after the word Fender. Maybe I'm a dumbass but I can't seem to find said number on the amp. I would GREATLY appreciate any assistance because I would really like to play through this beauty.
    P.S. Yes I put in a rectifier tube. Not sure if it's good hence the bulb question.
    Deluxe Reverb AB763, AB868 (silverface)
    A24000 to A26000 - 1967
    A26000 to A28500 - 1968
    A28500 to A33000 - 1969
    A31000 to A33000 - 1970
    A33000 to A34500 - 1971
    A34500 to A37000 - 1972
    A37000 to A39000 - 1973
    A39000 to A42000 - 1974
    A42000 to A43000 - 1975
    A43000 to A45000 - 1976
    AB763
    http://www.schematicheaven.com/fende...b763_schem.pdf
    AB868
    http://www.schematicheaven.com/fende...b868_schem.pdf
    the "pilot lamp" is connected to the green heater wires @ 6.3v
    you can see the layout in the AB763 link how it is hooked up
    the replacement bulb is a "47" you may be able to find one at an old hardware store.
    Ray
