P90 and Jazzmaster
  • P90 and Jazzmaster
    Does anyone happen to know if Gibby P90's will fit in Jazzmaster pup covers? I'm putting a partso JM together and using the JM pup covers would certainly make my life simpler. I have no problem with yanking the covers off the P90's if they'll somehow fit. And I don't have the JM pups or covers.
    thanks
    Charlie
    Yes it will, but the pole spacing is different.
    I did one of these back in the 80's for the guitarist in my band. He had a nice candyapple red Jazzmaster, but was missing the tone of his non reverse Firebird with P-90s. So I replaced the bridge Jazzmaster pickup with a P-90, putting it in the stock Jazzmaster cover.
    I had a 70's P-90 laying around that was taken from an SG. What I did was remove the pole screws, and took a small jewelers round file, and filed the holes wider, so I could move the screws to match the Jazzmaster's cover. This was one of the P-90s with the clear bobbins. I don't remember it having a keeper, but it was 24 years ago! It might have and I probably drilled it out.
    It wasn't hard to do though, and came out great.
      Thanks, David
      Unfortunately that now becomes moot since I read that USA JM pup covers do not fit MIJ JM bodies! And of course the one that I have is MIJ. So I guess I will just go with Plan A, which was get the pups in the body in the right spot and then have a new pg made. I have a MIJ pg that I scored off a classified some time ago so it is just a matter of dup'ing that and making the holes fit the P90's. Or maybe just making some pup rings which could be cool. No biggie.
      But thanks for the info anyway - it coulda worked
      Charlie
