New specifications
  • New specifications
    So in offering some advoce in another thread, I came across the amplifier spec sheet. On it was this entry
    This machine use grade gallbladder *7 of 12As not famous with behind grade use by gallbladder the EL84s and top-grade English walnut side board not wooden not real not famous.
    For the life of me, I cannot figure out what this is even supposed to mean.
    I get that the wood end panels are not real wood. But gallbladder grade tubes?
    And don't call me Shirley...
      Was that a post by KLDGuitar?
        Computer translator I guess.
        7 * (times) 12As = 12A X 7
        grade gallbladder? type valve / valve type?
        What was the amp?
          behold the wonders of machine translation
            It was that Yaqin MC-84L that Thatnaysayer asked about. it is Chinese, and obviously the trans-literation didn't work. I am having a hard time deciding what the gallbladder transliteration was intended to be.
              Using an online translator I reverse translated glaabladder and then copied the two Chinese characters (that mean gallblader in english) and translated those back into english...
              The result was... (drumroll)... gallblader
              But, when each Chinese character is translated the results are more interesting. The first character means "courage" or "bravery". The second means "bag, purse or sack" or "to put in a bag".
              This still leaves no clue (to me at least) about how that translation came about. Perhaps it means that it took real bravery and courage to put those tubes into such a sack of an amp.
              Chuck
                the machine (the program) sometimes gets confused and picks something not related IME (well, seems that way) so maybe that's what it is. What the heck is the latter part though? "Not real, not famous", etc. Plastic? Faux-wood?
                  Could "gallbladder" mean vacuum tube?
                  Could "not famous" mean un-matched?
                  And "grade" appears to refer to the pre-amp and "behind grade" the power amp.
                    lol, puzzler... We need someone Chinese. Could be obvious to a Chinese person (or speaker).
                      I feel pretty confident the last line means the end wood panels are English Walnut in appearance, but fake. SO it is not real English walnut wood.
