It hisses. I just had one in the shop and it did not hiss. I plugged in to the headphone and xlr line out and there is no hiss. I am assuming it would be in the output section. Suggestions on what to be looking for?? Could not find any loose grounds and bad solder connections. Resoldered cold joints on all pots and jacks. I have attached a schematic.
ampeg ba210sp bass amp
Reasonable to assume it is from the power amp. Hiss is usually associated with gain, so the first suspect is the IC. Replace the 5532, U3.
Scope the circuit. The hiss ought to be visible on pin7 of U3. Is it on pin 1 as well?
One of those JFETs could be noisy.Education is what you're left with after you have forgotten what you have learned.
It is only my opinion. I doubt that hiss is coming from your output transistors, especially since you find the noise on pin1 of the IC.Education is what you're left with after you have forgotten what you have learned.
