Results 1 to 4 of 4
Thread: impedence rule of thumb?
    New Member
    Sep 2009
    4
    Question impedence rule of thumb?
    i recently purchaced a crate gt412st cab and valveking 100w tube head. what would be the proper omhs settings for this set up? the cab has a switch for 16/4 omhs mono and an 8 omhs stereo. the head has 16/8/4 switch with 2 speaker jacks that can be paralleled. i looked through threads and online to no avail. if the cab is supposed to be at 8omhs do i have to run 8omhs on head but as stereo on the cab. the 4/8 omhs setting is in same position on selector switch for the cab.if you can help me out i would appreciate it.thank you for your time.
    Old Timer defaced's Avatar
    Dec 2006
    York Pa
    1,394
    Run the head in either 4 or 16 ohms, and use the matching setting on the cab. Since the 8 ohm setting on the cab is stereo, I wouldn't bother with it unless you're trying to drive it using two different heads.
    -Mike
    New Member
    Sep 2009
    4
    would one selection be better than the other as far as performance and safety to components?
    484
    Quote Originally Posted by Skeet Bonham View Post
    No.
    But you may notice a subtle difference in sound. Choose what you like better.
  1. General Question about impedence
    By Gatts in forum Cabinetry
    Last Post: 08-02-2009, 02:39 PM
  2. Ohm's Law and Power Slide Rule
    By Enzo in forum Theory & Design
    Last Post: 07-07-2009, 12:44 AM
  3. Replies: 4
    Last Post: 08-27-2008, 06:14 PM
  4. OT impedence
    By brian newman in forum Tweed Builders
    Last Post: 02-14-2008, 07:21 PM
  5. Making flatwork? Steel Rule Dies?
    By R.G. in forum Pickup Makers
    Last Post: 09-07-2007, 08:52 PM
