I just built a 5e3 amp using a hoffman board kit inside an old PE tube pa head that was gutted of everythign but transformers and sockets. I wired my board in using 6sl7 tubes in the preamp, and changed the cathode resistor from a 250 ohm one to a 390 ohm one, which feels liek it has less compression, more attack, and runs a little cleaner. High and low gain on the bright channel, and just high gain on the normal channel. It was my first build, and it was a lot of fun. :-)
New Member, first build.
you'll be hooked soon and building others!
how does it sound?
have any hum issues?
what kind of speaker are you using?
I built my 5E3 as a head unit also, my fave speaker cab is a 1x12 with a Weber sig series ALNICO, I was all excited this week when the Eminence Wizzard came (slate to reside in my AC30 ish build), I was at first disapointed at the sound on the 5E3, but realized what a truely good deal I got on that Weber and that made me feel pretty good.
congrats on your first sucessful build.
keep up the interest in amp building and maybe we will have a discussion on lead dress.
Since I got my first tube amp, a silverface bandmaster stack, when i was 16, I've never played anythign that wasn't tube. I know there is a certain amount of hum associated with these beasts, but this amp has a little more, lower frequency hum than I'm acustomed to. I've played a few silvertones, old ampegs, and the like. Like i said. It doesn't get louder, and I can only notice it when I first turn it on and don't play anything.
As far as the Lady Lucks go, I thought they were still installing them in the Valve Jr. cabs. They came stock in that and the so-cal 4x12 cabs Epi built. But i use this cab with this speaker for every head i have. or have had in recent history anyways. It's open-back, and works well with the 5e3 type amps...
