I mentioned an old 500-watt soldering iron I bought for $2.00 at a used tools store. All it needed was a new power cord. Anyway, here is a photo. The gridlines are 1" apart. The iron weighs 1.25 Kg (2.75 pounds). The tip is copper, the body is mild steel, and the handle is painted wood (with an airspace near the tip to keep the handle from getting too hot).
A real soldering iron
Now show us how to use this on SMD componentsAleksander Niemand
Wow, that's a big sucker! I have an old one that's pretty big... but not that big.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
I remember one exactly like that in the showed scene from the movie "Psycho." What a horrible way to die....http://www.SDpickups.com
Stephens Design Pickups
I type too fast when I get up....THE SHOWER SCENE FROM "PSYCHO"....http://www.SDpickups.com
Originally posted by Possum View PostI type too fast when I get up....THE SHOWER SCENE FROM "PSYCHO"....It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
That's beginning to look a lot less like a soldering iron and a lot more like a stake for killing werewolves. Vampires, even, if the handle is hawthorn...Pickup prototype checklist: [x] FR4 [x] Cu AWG 42 [x] Neo magnets [x] Willpower [ ] Time - Winding suspended due to exams.
Originally posted by David SchwabThen you have neos... which is a fuzzy bunny wrapped in barbed wire.
Edit button, where the hell is that? Oh, ok now I see it, didn' know about that. Now how do you do those quotes thingys?http://www.SDpickups.com
Back when Plumbers worked with lead (Pb) pipe, all joints were sweated between the pipes with a thing like this. Before electricity, they usually had a coal or charcoal filled bucket to keep several of them hot while they worked with one. I have some I got from my grandfather that are about 18" long and weigh 3-4 pounds each. (He wasn't a plumber but a physicist at Bell Labs.). He dream in later life was to create a water sprinkler that watered evenly over a perfectly square patch of lawn. I don't think the corded ones were big enough for his uses but I remember him firing his up over the gas stove in the kitchen and taking them out to his workshop next to the garage to try soldering his pile of brass gears, cams shafts, pipes and nozzles together.
