Hi,
I recently bought a Peavey Bandit 112 second-hand that's started popping. Anything that disturbs it, whether it's playing it above very, very low volumes or tapping it, makes it start popping at max volume until it cuts out, gets smacked and stops for a while or turned off.
I'd guess this is a bad connection somewhere on the boards but I have no idea where. I'd rather not go through the mess of having to completely take it apart and examine all of it so i'm wondering how I'd make sure that it is a cold joint and if I can figure out where. On the back of the the amp there's 1/4" jacks for effects send and return, preamp out, power amp in, an external cab and a footswitch. Haven't had the chance yet to mess around with a spare cable plugging it in to different places and seeing what happens and i'm not entirely sure how to go about it anyway.
Might be worth mentioning that i've been having trouble with the footswitch. When I plug it in it stays on the clean channel all the time like I think it should when the footswitch is in but neither switch does anything. I thought this might have been down to a wire being broken inside the cable since the cable was in tons of knots when I bought it but maybe there's something wrong with the jack.
