I'm new to pickup winding.I have the parts to make my first. I've done weekend research and am happy to have found this site.I'm an electrician, and with an auto transformer there are tap connections in the transformer coil, giving you access to variable voltage outputs.Would the same application apply to a guitar pickup? Lets say during the 6000th wind,pull an inch of coil wire out from the bobbin, roll it in your finger to create a tap then continue winding to 7500,and repeat ect. Would this give easy access to multiple sounds from the same pickup? and by adding a rotary switch would you be able to dial in different tones?
multiple taps on coil winding??
