I have a GK 200mv--used too big of an extension speaker (4ohms-100w) and can no longer use the extension speaker even when I turn off the internal speaker (internal speaker works)--any ideas as to how to correct?-----ED
Gallien Kreuger 200mv
It works with the internal speakers on? That means the amplifier circuit works. That doesn;t leave much, just the extension speaker jack and the connections to it, and the switch.
If you overloaded the amp, it more likely would have blown the output stage than to cause the extension jack to stop working.Education is what you're left with after you have forgotten what you have learned.
