Results 1 to 8 of 8
Thread: Output jack problem
    New Member
    Nov 2009
    3
    0
    Output jack problem
    Hello,
    First post here. I tried searching but could'nt find anything, sorry if i missed it.
    I've got a problem with the output jack on my BC Rich KKV '08.
    There is sound coming from it until it's all the way in, then there's no sound.
    Nothing wrong with my equipment as i've tried another guitar, and that works fine.
    I've tried soldering 3 times now, stripping the wires so that it's "fresh". Also cleaning the output jack etc.
    Can this be fixed with a new output jack, or is it something deeper in my guitar that's gone wrong?
    Noodle of Reality Steve Conner's Avatar
    Glasgow, Scotland
    7,251
    Received: 14/0
    23
    New output jack should do it.
    Is it one of these?
    Flush-mount Output Jack at Stewart-MacDonald
    They seem to break down pretty quick compared to ordinary jacks.
    New Member
    Nov 2009
    3
    0
    Thanks for the quick reply.
    Not the one in the picture. It looks like a standard stereo output jack.
    Like this:
    Jack Socket stereo SJ3 - gitarhuset.no
    Hopefully a new one will fix it. (crosses fingers and toes)
    Glasgow, Scotland
    7,251
    Received: 14/0
    23
    Oh, well those can still break, I suppose. Try to get a Switchcraft one, they're a bit higher quality. Or you can try to fix your existing one, bend the springy tip contact inwards so it presses on the plug tip harder.
    If you don't understand what I mean, insert the plug while the jack is dismantled off the guitar, and you'll see how the mechanism works.
    Music Lover Sock Puppet's Avatar
    Aug 2006
    Northumberland U.K.
    413
    Given: 1/0
    14
    Quote Originally Posted by Steve Conner View Post
    +1 there Steve. I've had brand new guitars through my hands where a quick slight bend with a pair of fine pliers has made the jack plug "snap" into place.
    New Member
    Nov 2009
    3
    0
    Tried that too.
    Anyway, the place i bought the guitar from ("Thomann", in Europe)
    believed it was a faulty output jack aswell. So they're sending me a pre soldered one for free
    I'll update when it arrives
    Senior Member Plucky's Avatar
    Feb 2009
    Vancouver, BC
    111
    12
    Hi. Sounds like your jack is grounding out on shielding paint. Does it work when the jack is unmounted and pulled out of the cavity? If so, there's your prob. Good luck!
    May 2009
    36
    0
    I have recently changed out a couple of open frame mono outputs jacks on 2 Squires. They had tried to make the connections tighter by bending the tabs closer and cleaning, worked for a while but problems returned. Once I installed the new jacks they worked fine. They said that the plugs had a much better, tighter fit as well.
  1. Ampeg B-15 speaker output problem
    By stratslider in forum Repair and Restoration
    Last Post: 10-05-2009, 04:15 PM
  2. Problem: Weber 5F6A with very low output!
    By jibe in forum Tweed Builders
    Last Post: 08-03-2009, 02:01 PM
  3. Univibe output problem
    By ronh in forum Guitar Effects
    Last Post: 05-14-2009, 06:31 AM
  4. 5F1 Do I need to ground this output jack?
    By cat in forum Tweed Builders
    Last Post: 04-24-2009, 01:18 PM
  5. Please help, how to install output jack on Hammond L100.
    By himtroy in forum Music Electronics
    Last Post: 08-26-2008, 05:35 PM
