Results 1 to 3 of 3
Thread: UK Marshall 8008 240V in US
    New Member
    Nov 2009
    2
    A Marshall 8008 was given to me. It's a 230V version but I live and would like to use it in the US at 120V. The circuit board has different jumpers for the 2 voltages which lead to the transformer. It also indicates different fuse ratings for each as well.
    Other than acquiring a monster external transformer, is there an easier means to modify this amp to use US current.
    BIG THANKS....!!!!
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,943
    Received: 892/5
    Looks to be a universal transformer already. Look at the schematic, and compare to the existing wiring. It appears you will need to remove the 240v jumper wire, and add two 120v jumper wires, and then install the larger value fuse.
    Attached Thumbnails Attached Thumbnails Marshall 8008.pdf
    New Member
    Nov 2009
    2
    Big thanks enzo......!!!!
    YOU ARE OBVIOUSLY DA MAN......!!!!!
    On my way to 'the Shack' to get fuses.....!!!! can't thank you enough....!!!
    Smoov
  1. valvastate 8008 blowing secondary fuses
    By Poffa in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-24-2012, 08:44 AM
  2. MOV in 120/240V dual primary
    By MarshallPlexi in forum Theory & Design
    Last Post: 03-02-2009, 12:18 AM
  3. Marshall Valvestate 8008 pots, log or lin?
    By Delta in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-30-2008, 11:40 AM
  4. 5E3 Power Trannie 240V ?
    By nickt in forum 5 E 3
    Last Post: 12-10-2007, 01:44 PM
  5. Ampeg SVT 3 Pro conerstion to 240V Australian
    By shaneo in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-26-2007, 04:04 AM
Tags for this Thread
