Results 1 to 4 of 4
Thread: loud growling hum in ab763 clone
    Sep 2009
    51
    my first build now amplifies now :-there is a buzz(not worried about that yet), but much worse is a loud, Moog like growl when i turn the amp above about two . If I put a guitar in the noise disappears and the guitar is amplified, but as soon as I unplug it comes back.
    I tried disconnecting the preamp stage from the PI input and the growl still came out of the speaker. I am concluding its not preamp related- so think its either PI, Power stage or Herater related
    The amp is , essentially the vibrato section of a AB 763 , but without the vibrato bit
    All the voltages and currents in preamp are good, I havent measured power amp current ( I dont know how!)
    I am an absolute beginner and the forum helped me get noise from the thing, I have posted this new thread as the issue is different to my original 'no sound' problem
    could this be about a push pull problem, or is it something else
    any help appreciated
    chris
    Last edited by chris shaw; 11-29-2009 at 12:20 PM. Reason: missed space in title and bad description
    Dec 2008
    Wernersville, PA
    12,452
    Received: 181/2
    Given: 84/0
    Grounding Jack
    Are you using a grounding input jack?
    It has an extra tab that should attach to ground when no input is inserted.
    Sep 2009
    51
    Will try later
    Thanks , will check tonight and respond
    Sep 2009
    51
    partial success!!
    thanks jazz p bass the 1 meg input resistor wasnt connected correctly. This has stopped the oscillation at input (how did it get into power stage when pre amp had been disconnected?!)
    nonetheless I am left with the following:-
    a hum/ buzzing tone which comes on when amp is turned on, is quite loud , can get louder as amp volume is turned up BUT if i put a cd player through it , even with the cd player volume turned to zero the buzzing will reduce as I turn up the volume of the built amp (not the CD) to 1 or 2 ,
    if I pull the cd player jack plug out the buzz comes immediately back even if the volume of the amp is set at a level which, with the cd player connected has previously reduced the buzz level to very low
    I am assuming this is a grounding issue ?!!!,
  1. Large Radial Caps
    By lowell in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-22-2009, 02:01 AM
  2. Using large value screen resistors w/ bypass caps
    By Chrome Dinette in forum Tubes (Valves)
    Last Post: 07-19-2009, 06:21 PM
  3. 1x12 from large a pipe
    By Guitarist in forum Cabinetry
    Last Post: 04-11-2009, 06:03 PM
  4. Any large retailers still sell fuses???
    By ctcpete in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-27-2009, 05:29 PM
  5. Best/worst large manufacturers?
    By Euthymia in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-14-2007, 04:36 AM
