Blue Voodoo clean channel hiss without volume
  • Blue Voodoo clean channel hiss without volume
    This may be a complete newb question, but can someone give me some pointers about what to look for on this issue? I have a BV6212 amp that is from the mid 90's. I noticed the clean channel has hiss even when the volume is completely off. I replaced all the tubes and didn't see much if any difference. I tried pulling individual tubes but the hiss didn't go away until the channel went away. Is this a component problem?
    Probably. If it isn't a tube, not much left. Resistors get noisy.
      So I'm looking for a bad resistor? I was planning on doing some component checking anyway. I'll see what I find.
        YOu need to...
        isolate the problem.
        FInd out where the noise is and is not. You shoulod be able to narrow it down to a stage.
