Part Identification
  • Part Identification
    Hello All,
    I am trying to identify some caps and diodes. Wondered if anyone could help me identify these parts and where I might be able to find them. It's important to me that I find the same parts, and not just alternates.
    I am looking at:
    1) .001uF
    2) .01uF
    3) 1.0uF
    4) 1N4001
    5) 22MF (blue)
    6) 22MF (gold)
    7) 47pF
    8) MR500? diode
    Thanks!
    Cameron
    You've already identified them, plus, the values are printed on the PCB. If you can locate a schematic, you can double check values. As long as the voltage for the parts is the same or higher, and the part is of the same construction(ceramic vs. film vs. E-lytic cap, etc.), they will work. If you're hung up on the color of the wrapping, just call the manufacturer and order replacement parts.
