I need the pot that goes on the printed circuit board in the plug in preamp on the ovation guitar. Thanks for looking......Cap
Need pot volume control for op pro preamp Ovation Guitar
How'd ya get'em to replace *anything*? I have a CS257 flametop I bought new. The second time I used the preamp it died...onstage. Ovation wouldn't either replace the preamp or send service info for it....and it was under warrantee. So I said f**k Ovation and the thing sat in the case for 10 years. I got it out and repaired the preamp prolly about a year ago for no apparent reason.....The farmer takes a wife, the barber takes a pole....
Hmm.....well good for you then. I talked to Ovation and they basically told me to buy a new preamp assy for 100$ bucks or piss off. DOn't remember if I talked to Elderly on it or not. Maybe they had enough ppl bitching at them that it caused them to change the policy. Ovations are meant to be used plugged in...they don't really cut it as an acoustic instrument.The farmer takes a wife, the barber takes a pole....
Take a pill mahn....I wasn't slammin' 'em, just stating the fact that they were/are primarily intended to be used plugged in. Thats where they excell....
Same goes for the Telecoustic and other similar guitars.The farmer takes a wife, the barber takes a pole....
Those ovations are made to project sound outward, gets more sound to a small audience than a conventional body. SO it is more a live act guitar than say a recording guitar.Education is what you're left with after you have forgotten what you have learned.
