Hi, I have finished building a JTM45 copy based on a metroamp schematic. I have tested the amp today. The sound is excellent and everything is working as it should apart from a loud buzzing that gets worse as the amps volume is increased. The buzz is there all the time even when nothing is plugged in to the inputs. I have checked over the circuit and voltages etc. and all seems well. Any ideas?
JTM 45 Clone buzz/hiss
Volume potentiometer
Is there any Vdc on the top leg of the pot?
There should be none.
If there is the cap before it is leaking.
Does the buzz go away if you ground the input?
Can you post a schematic?Last edited by Jazz P Bass; 12-24-2009, 08:50 PM.
