Results 1 to 6 of 6
Thread: 5F2-A tone pot, log or lin?
    Junior Member
    Dec 2009
    Seattle
    10
    0
    Hi,
    I am building a nice 5F2-A as my first amp. I have looked into several schematic before and usually Volume pot are always LOG. and EQ pot are sometime LOG or LIN (I noticed bass and mid usually are LOG while trebble is usually LIN). This 5F2-A has only a tone pot and is not specificied which type. Is there a logic to know if it's LOG or LIN for a tone pot? My guess would be LIN, but I'm not sure. I'm talking about the 1M pot with 2 legs between a 0.005uF cap and a 0.0005uF cap. Thanks
    Senior Member ThermionicScott's Avatar
    Dec 2009
    SW CR IA US NA PE
    608
    10
    The 5F2A layout specifies linear pots for both, but I used log pots in mine.
    - Scott
    Dec 2008
    Wernersville, PA
    12,940
    Received: 533/3
    Given: 288/0
    26
    Log or Lin
    Depends where you want it to happen.
    Log will "happen at one end & quicker.
    A linear taper will allow a smooth transistion & it will also allow for a middle setting.
    Dec 2009
    SW CR IA US NA PE
    608
    10
    Quote Originally Posted by Jazz P Bass View Post
    Electrically, linear taper pots have a smooth progression from one end to the other. But to our logarithmic ears, linear pots are "all in" early in the rotation, while log pots seem smoother. That's why log pots are often referred to as having "audio taper".
    - Scott
    Junior Member
    Dec 2009
    Seattle
    10
    0
    Thanks Scott. I already know about the theory of log pots. My issue was that I could not find the specs for the pot on 5F2-A, where did you find it? Can you post a link? Thanks a lot.
    Dec 2009
    SW CR IA US NA PE
    608
    10
  1. Tone control in Tweed Princeton 5F2-A Clone
    By cathode in forum Build Your Amp
    Last Post: 04-25-2009, 02:51 AM
  2. 5F1 & 5F2-A Much of a tone differenece??
    By Ringwraith in forum Tweed Builders
    Last Post: 04-23-2009, 11:08 PM
  3. Need help wiring tone pot and ground.
    By Bmxbarspin724 in forum Music Electronics
    Last Post: 11-17-2008, 08:15 PM
  4. Marshall Valvestate 8008 pots, log or lin?
    By Delta in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-30-2008, 12:40 PM
  5. Custom tone pot and caps (and anything else)
    By 8donovang in forum Guitar Tech
    Last Post: 05-30-2008, 01:51 PM
