My new proluxe gets chimey when I hit certain notes. I've swapped out tubes to no avail and the only thing that does it is using an external cabinet and mechanically isolating my amp from it (I can't even set the amp on the cabinet). Once I do that I can go all the way to full volume with no chimeyness whatsoever. Do I have to isolate my chassis with any kind of damping from the cabinet or glue down the caps on the fiberboard? I can pretty much chopstick anything under the hood and make it do it , it's that sensitive.
5E3 Proluxe chiming
If you "can pretty much chopstick anything under the hood and make it do it" then there is something there that you can eventually find and fix. Tubes aren't the only culprits. Caps and even coax wiring can be microphonic. If it's a cap then gluing everything down could potentially make make the problem worse or harder to find. I suggest you keep looking for the root cause rather than work on a cover up fix. Maybe give it a rest then poke around inside again later.
Regards,
Tom
Poke around will the volume controls all the way down. If it still does it, that eliminates any component before the volume controls. Run the amp with the 2nd preamp tube removed. If it still does it, that eliminates a few more components.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Glad you found the problem. Thanks for letting us know what you ultimately found.
This is a good troubleshooting lesson, i.e. after you have substituted a "known good part" you can't totally rule out that part. Then there is the situation where a combination of things are causing the symptoms.
Regards,
Tom
