Alpha Voltages
  • Alpha Voltages
    I need to know what are the operating voltages on this amp. Its a Alpha Slave 100w power amp .
    the ac out of the trans is 64v
    and the DC out of the rect is 46V.
    Is this about right for these?
    I dont have a scem yet.
    Assuming your 64VAC is center tapped with center grounded, then 45-46v is the DC I'd expect. 64VAC CT is really 32v on either side.
      ok, thanks.
      look like the power switch was the only problem. I ran a mic thru the amp and it seems ok .
