Adding line out
  • Adding line out
    I have a SF Fender Princeton and would like to add a line out for slaving. I will probably add it just before the PI (I have also seen them taken from the speaker jack) and have an unused triode (I don't use the tremolo). I am considering turning the unused triode into a cathode follower and feeding the line out with this. Would it be better to have the cathode follower feed the PI and the line out? BTW the PI is a split load type if that makes a difference.
    here's a thread with line out through the speaker jack:
    http://music-electronics-forum.com/s...6&goto=newpost
    or
    http://www.diyguitarist.com/GuitarAmps/LineOutBox.htm
    hope this helps!
