1 speaker vs 2 speakers
Originally posted by Bruce / Mission Amps View PostIt is generally accepted that with two really good 12" speakers (high SPL per watt).... you can expect that combo will be quite a bit louder than the same amp using a single 12".
What that infers is that a 20-30 watt amp driving a 2x12 bottom will sound as loud as a 50-60 watt driving a single 12" cab.
I would always go with the lower wattage and two better speakers.
Originally posted by GibsonLover View PostIt also takes 10 times the power for twice the volume, not achievable by adding one speaker.
Originally posted by Glass Snuff View PostThis is also not true, no matter how many times it's repeated on the internet. For hundreds of years, it's been accepted that if you want a violin part to be twice as loud, you hire three more violinists. That's four times the power, which is +6 dB.
Cheers,
Tom
Doubling the Sound Pressure yields a 6db increase (your violin example)
Doubling the Sound Power yields a 3db increase (what some people are talking about on this thread, amplifier power)
Doubling the "loudness" or Sound Perception in the mind of a human being (according to Psychoacoustical researchers) is approximately around the 10db mark.
Originally posted by ZeroCool View PostYou're confusing Sound Pressure with Sound Power and with Sound Perception, they are NOT the same.
Originally posted by ZeroCool View PostDoubling the "loudness" or Sound Perception in the mind of a human being (according to Psychoacoustical researchers) is approximately around the 10db mark.
Trust me, if you put ten Champs onstage, and play through one, then play through all ten, no one in the audience is going to think it's merely "twice as loud".
Originally posted by Glass Snuff View PostTrust me, if you put ten Champs onstage, and play through one, then play through all ten, no one in the audience is going to think it's merely "twice as loud".
Originally posted by Glass Snuff View PostNo, I'm not. You are confused - sound power and sound pressure are the same, it's simply one is expressed in watts, the other as a referenced SPL.
Loudness volume sound level change factor of loudness formula calculate power level noise levels volume logarithm dependence three four fold loudness sound - by what factor does level decrease dependence comparison decibel levels 3 dBSPL 6 dB 10 db d
This guy Eberhard Sengpiel, a multiple Grammy award-winning sound engineer (who studied electrical engineering) thinks that "Double the sound pressure is a SPL of +6 dB" Who does he think he is to say such a thing??
FAQ in music acoustics
In this article the Professors at this University say that "doubling the sound pressure gives an increase of four in the intensity, so an increase in the sound level of 6 dB, whereas doubling the power increases the intensity by a factor of two, so an increase of 3 dB."----those idiots!
http://www.kraftpower.com/pdfs/KPCInfo03_Sound.pdf
According to this team of foolish engineers "Sound power value is higher than given for sound pressure, because they are not affected by the ambient. For example a 60kW generator set measured has a sound power of 94.4dBA and sound pressure 66.9dBA" Maybe you should give them a call tell them that's ridiculous since both sound power and sound pressure are the same.
http://www.energymaine.com/brwind/br...ort_091206.pdf
According to this engineer from Wind Energy Consulting and Engineering, if you look at the graph on Page 4 (to which he refers on Page 3), the addition of two sound sources each producing the same db will yield a 3db gain, but again, maybe you should contact and educate this engineer as well.
I give you the benefit of the doubt in that maybe you thought I meant Sound Intensity when I said Sound Power, Sound Intensity is the one that is practically (but not theoretically) the same as Sound Pressure since both are trying to measure a unit of energy or force per unit of area. Sound Power is independent of space, however, Sound Intensity IS dependent on space and so it's basically Sound Power per unit of area (W/m^2). Sound Pressure is also dependent on space, hence the similarity to Sound Intensity.
I hope this helps.
Sound pressure level (SPL) and sound power level (SWL) are related the same way as voltage and electrical power, when those are measured in dB.
So, a doubling of the sound pressure means that both SPL and SWL increase by 6dB.
A doubling of acoustic power means that both SPL and SWL increase by 3dB.
This seems non-intuitive, but it stems from the fact that dB are always power units, even when you use them to measure quantities that don't have dimensions of power. I don't have a problem with this, but when I worked with fiber optics I always struggled with "electrical" vs. "optical" dB. Optical ones are twice as big, so to make a laser power meter with a range of 60 optical dB, the electronics need a dynamic range of 120dB.
SPL and SWL have different definitions, so they can have different values as in the case of the generator set. For instance, SPL is whatever a SPL meter measures 1 meter away, and SWL is an estimate of the total acoustic power emitted by the device, which you calculate from a number of SPL readings taken in a sphere around it. If the source has directivity, then SPL and SWL can be very different.
But assuming the same source, changes in sound level always obey the above rules. Ganging up more amps or speakers, it isn't the same source any more: in particular the directivity is increased, so if you stand in a lobe of your new ghetto line array, you get more SPL for the same SWL."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
Originally posted by Steve Conner View PostSo, a doubling of the sound pressure means that both SPL and SWL increase by 6dB.
I said that earlier too, but to no avail, maybe he'll listen to you.
Originally posted by Steve Conner View PostGanging up more amps or speakers, it isn't the same source any more: in particular the directivity is increased, so if you stand in a lobe of your new ghetto line array, you get more SPL for the same SWL.
Well, I wouldn't say it was "bad", just different.
If you gang a bunch of Champs together, then each has its own power amp built in, so the SWL will increase for each amp you add. And the directivity gain will give a SPL increase on top of that.
If you connect a bunch of speakers to the same amp, then the SWL will stay the same. The speakers all have the same efficiency, and the electrical power is the same as it was, so conservation of energy demands it. But you can find some point in the room where the SPL will increase because of the directivity gain.
Many people like to think of this directivity gain as an "increase in efficiency" of the speakers caused by ganging them up. And I think there are also coupling effects in the bass region that really do make the efficiency of a woofer array better than a single woofer, similar to directivity gain but not quite, because the SWL actually goes up too."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
Originally posted by Steve Conner View PostWell, I wouldn't say it was "bad", just different.Last edited by ZeroCool; 02-03-2010, 04:50 PM.
so an amp with one 8ohm speaker will be 3db quieter than the same amp (at the same gain) driving two parallel 8 ohm speakers (4 ohm total load)...right?
And a 4 speaker cab wired to 16ohms will be 3db louder than a single 8 ohm speaker at the same gain setting?
On a related issue, the majority of large touring acts have a huge amount of dummy speaker cabs (Brad Paisley's wall o' fake Dr. Zs come to mind) so the PA can handle all the volume, they don't blow out their ears with the backline and they're still COOL looking.
Originally posted by Tom Phillips View PostIf you want to challenge accepted theory then you should provide a cite(s) to support your position
