With all the talk of elevated heaters here lately, I haven't seen anything about how one goes about doing it without a CT on the PT for the heaters. How would you do that?
Elevating Heaters with No Center Tap?
Originally posted by wizard333 View PostWith all the talk of elevated heaters here lately, I haven't seen anything about how one goes about doing it without a CT on the PT for the heaters. How would you do that?
In many instances of lesser-quality power transformers, this can be a more accurate centertap than a winding one. Sometimes it's a lower hum option to use the resistors as a CT even if there's a winding CT.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Or in place of the 2 x 100Rs, use a 250R-500R pot with the input and output respectively connected one to each side of the heater winding, and the wiper becomes the CT, which gets connected to the elevated DC supply = an elevated humdinger. Should be really quiet when you dial the pot in (by ear)Building a better world (one tube amp at a time)
So on say a vintage Fender, where they create the virtual center tap over at the pilot light with the two 100ohm resistors, you'd lift those off ground, then that becomes what you'd connect your dc bias to?
Any reason for those to be 100ohms vs 1K, etc?
I like the idea of a pot to, brings the whole "hum balance" control into it along with the biased heaters.
Any suggestions for pots in that value range that can stand up to the constant DC? Can't really toss a 10k bias pot in there.
On the schematic Tubeswell posted, the resistors are labeled as precentages. Does the value matter so long as that ratio is maintained? Assuming you arent subbing for one of the 220k resistors across the resevior caps.
Also, if I wasn't subbing for one of the 220k resistors across the resevior caps, should I draw my voltage from further up the power rail, like the screen supply, PI supply, or pre-amp supply?
Thanks!Last edited by wizard333; 01-11-2010, 08:44 AM.
Also, if I wasn't subbing for one of the 220k resistors across the resevior caps, should I draw my voltage from further up the power rail, like the screen supply, PI supply, or pre-amp supply?-Mike
What's the rationale for creating an artificial centre tap with elevated heaters?
My understanding was that the heaters should be elevated such that the (pre-amp) heaters are always above the cathodes.
That can be achieved by referencing 1 of the heater legs to say 20V (and leave the other leg floating) - why mess around with 100 ohm resistors / pot?My band:- http://www.youtube.com/user/RedwingBand
Well my take on the pot is that it works like two 100R resistors, only you can finely tune the balance between the two AC sides of the heater winding, which is theoretically better (but it is also just more knobs to fiddle with). Any 1/2Watt linear pot would be fine.
Whereas the elevation lifts the entire VAC wobble above the ground potential reference point of the cathodes, so that this doesn't interfere with the signal. It certainly makes it quieter.
I'd never heard of just ground referencing one side of the heater winding and leaving the other one floating before. I thought the whole point was to have both sides of the winding referenced evenly, in order to get the same amount of opposing VAC in each side, which cancels out better when the AC pairs are close/twisted together.(But my ejamacatian stands to be improved as usual)
As for the voltage divider, if it is coming from the HT the 220k total is a good standard load (doubles as bleeder circuit), and 90/10 could be achieved with two 390k 1W in parallel (giving 195K 2W) for the "90" in series with a 22k 1W for the "10", and put the 10uF cap in parallel with the 22k to get about 40V from a 400V B+.
But you don't need 90/10, you could go for 85/15, or 80/20 etc. You probably don't want to go much above 90V h-k elevation with modern 12AX7s to be on the safe side.Last edited by tubeswell; 01-11-2010, 04:31 PM.Building a better world (one tube amp at a time)
Originally posted by otto pärt View PostIf my cypherin' is correct, you could use 1/2W resistors if you went with 470k + 56k or something like that. Is there downside to using even greater resistances? Or do you just lose the bleeder benefit?Building a better world (one tube amp at a time)
I'm clear on all of it except why the 2x100ohm resistors need to be 100ohm?
Fender used a 100ohm pot for hum balance which would be 2x50 ohm if it were centered for instance.
Any reason they need to be 100ohm? Or 50 ohm? What range of values works?
Originally posted by tubeswell View PostOr in place of the 2 x 100Rs, use a 250R-500R pot with the input and output respectively connected one to each side of the heater winding, and the wiper becomes the CT, which gets connected to the elevated DC supply = an elevated humdinger. Should be really quiet when you dial the pot in (by ear)
- the other sources of hum are power line frequency, not power supply ripple frequency
- the other hum sources are either in phase with or out of phase with the AC line. If they're, say, 60 degrees out of phase with the line, no amount of pot diddling will get perfect cancellation. This can happen with magnetically induced hum sometimes.
- the summation of the other hum sources which you're cancelling do not change. If they change, the cancellation is wrong.
But you can often get usefully less hum this way.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Originally posted by otto pärt View PostYou're confusing me. The formula is V^2 divided by R, right?
So (450V/500k) x 450V = 0.0009A x 450V = .405W
Whereas (450/250k) x 450V = 0.0018A x 450V = .81WBuilding a better world (one tube amp at a time)
100R is good because they don't get too hot and 1/2W is okay. If they were 50R they would heat up more and 1/2W wouldn't be enough. But it'd still probably work, although quite a bit less current would be available for the filaments (and don't forget the 6.3V lamp), so you have to be careful about the load on the winding.
On the other hand 200R-250R per side should work okay as well AFAICT. But if the resistance got too high, (say several hundred kohms) then you lose the ground reference I guess (but I never tried going really high).Building a better world (one tube amp at a time)
