Loose pups
  • Loose pups
    Hello all.
    Not sure if this is the correct place for this ?
    I have a guitar with two SD Zebra pups, the bridge pup is always coming loose. Even if its just left in the case?
    Could it be the springs, or the screws.
    Thanks for any help, Regards Dave obliouk
    How is it coming lose? The screws are coming out of the tabs on the pickup?
    If that's the case, it's the wrong size screw, or the threads on the pickup have stripped.
      Hello Dave,
      Most times it just drops a bit, But one time it came off one side completely.
      I have tried pushing down on them to see if it would slip , but it never.?
      I will take the strings off and have a good look. and let you know.
      Thanks for your reply.
      Regards from Dave obliouk.
